Some Vag-Com errors. Any help?
Address 01: Engine Labels: 06B-907-557-ALT.lbl
Part No SW: 8E0 907 557 F HW:
Component: 2.0L R4/5VS 0006
Coding: 0011581
Shop #: WSC 63351 000 00000
VCID: 346318E32CFB
6 Faults Found:
17700 - Map Controlled Engine Cooling Thermostat (F265): Open Circuit
P1292 - 004 - No Signal/Communication
17887 - Brake Boost Vacuum System: Mechanical Failure
P1479 - 008 - Implausible Signal
17536 - Fuel Trim; Bank 1 (Mult): System too Lean
P1128 - 001 - Upper Limit Exceeded - MIL ON
17927 - Camshaft Adjustment; Bank 1: Malfunction
P1519 - 008 - Implausible Signal - Intermittent
17545 - Fuel Trim: Bank 1 (Add): System too Rich
P1137 - 002 - Lower Limit Exceeded - MIL ON
16523 - Oxygen (Lambda) Sensor B1 S2: Response too Slow
P0139 - 002 - Lower Limit Exceeded - Intermittent
Readiness: 0000 1001
Here is more complicated. This is the first thing i want to solve first!
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No: 01J 927 156 AE
Component: V30 01J 2.0l 5V RdW 1756
Coding: 00001
Shop #: WSC 01414
VCID: 6FE9D78F055D
1 Fault Found:
17090 - Transmission Range Sensor (F125): Implausible Signal
P0706 - 35-00 - -
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front D620
Coding: 04279
Shop #: WSC 31224
VCID: E5C535A757A1
1 Fault Found:
01119 - Gear Recognition Signal
35-00 - -
I must change the computer of the gearbox or try just that switch to replace??
When i start the engine when is cold it seems to work perfect. After it's heating the problems start.
I can run and 300 miles with no errors if i don't stop the car. If i put on reverse while i driving, shows that there's not any gear selected and it's slowly activate the reverse. If i accelerate don't work..i need to let the car to reverse..on a hill it won't work..
Multitronic have a bad reputation for failing. I would suspect your tranny problem is easy, buy expensive; replace the tranny.
The important problem is on that auto trans. i think is the gearbox switch or i someone told me to replace the computer of the gearbox.
