speakers problem solution
Basically, my front speakers sometimes had some static-ish sounds when I drove on non-flat surface. It didn't occur all the time but frequently enough to get you annoyed.
6 months ago, I told the servicemen to check the speakers up but they did not find the problems, probably because they were working fine at the time of service.
And the problem came back like on the next day....
Finally, last week, I got annoyed enough that I went to service again. This time, they detected the problem and fixed it! Here is the fix: they cleaned the contacts to both front doors of the speakers.
Anyway, in case if you run into this problem, this is somewhere you could start working with.
