Thoughts on drilling a snub mount?
I've heard of lots of complaints about the N/S snub vibrating and thought that I may try to drill a few holes in the elastomer. Has anyone done this? reccomendations on hole sizes? Thanks
You can't drill urethane. The bit will go in but it only slices the material...
When you pull the drill bit out the hole closes up behind the bit. Thats the same reason urethanes of less than about 140 durometer hardness aren't machineable. But you can grind holes with a Foredom/Dremel or air grinder and a stone or high-speed metal burr.
N'Syncro
33
02-16-2020 03:12 PM
S4intheOC
09-08-2015 12:12 AM
