Tiptronic programming
Old Mar 16, 2002 | 06:43 PM
Marc Collins's Avatar
Junior Member
Default Tiptronic programming
Is there a link to an explanation of how/when the Tiptronic will override your commands?
I know it will downshift automatically when you come to a stop if you haven't already. Does it hold the car at redline or upshift for you?
Just drove a G35, which will not upshift, but has the most bizarre manumatic I have ever encountered: it acts like a traditional automatic up to the gear that you have selected. For example, if you stick it in "4", it will do nothing differently from "D" other than prevent the car from going into 5th gear!!! How is this different from a regular automatic?!?!? If you put it in "5" and give it some gas (not floored), it will downshift if it feels like it needs to. Otherwise a pretty interesting car...
Marc
Old Mar 16, 2002 | 06:53 PM
Jason in Vancouver's Avatar
Member
Default Audi tiptronic can choose the gear you desired not like the nissan one and it will upshift when...
redline
Old Mar 16, 2002 | 06:59 PM
joe v's Avatar
Default Re: Tiptronic programming
yes, it will upshift at redline in tip mode. speed warning can be adjusted as desired, or disabled. joe v.
Old Mar 16, 2002 | 07:23 PM
calberto's Avatar
Tiptronic will also downshift if you stomp the gas down to the floor, did it yesterday.
Old Mar 16, 2002 | 08:08 PM
April's Avatar
AudiWorld Uber User
Default If you exceed a certain amount of throttle travel in Tip mode, it downshifts as an
emergency measure. As in, you suddenly need to floor the car to clear an obstacle and forget to downshift.
Old Mar 17, 2002 | 08:24 AM
Junior Member
Default Re: If you exceed a certain amount of throttle travel in Tip mode, it downshifts as an
Short of suddenly flooring the throttle, will it override the seletion? For example, slowly pouring on gas but eventually flooring it?
Thanks,
Marc
Old Mar 17, 2002 | 08:26 AM
April's Avatar
AudiWorld Uber User
Nope. You keep full control in that situation.
Hy Octane
9
Apr 21, 2003 04:07 PM
023.0
Oct 12, 2002 06:12 PM
SILVERTONE
Apr 20, 2002 08:50 AM
BobT(nolonger)A6
Dec 11, 2000 01:47 PM
