tire problem
Old Jun 16, 2005 | 09:46 AM
Slow Sport Sedan's Avatar
New Member
Default tire problem
i kept putting off rotating my tires, so basically my front tires are done... i put my back tires which are toyo t1s (235/35/19)(50% worn) on the front. i bought 2 new toyo t1r (245/35/19) because i thought it would look beasty with wider back tires, this turned out to be a mistake..my car isn't driving normal..when i take a turn the car feels like there is a lot of body roll and it's driving worse than a SUV right now..Does any1 have any suggestions to how i can fix this. i'm starting to think i may have to buy new front tires the same size as the rears, but i hate to spend another 400$ on tires when they still have so much tread on them.. i appreciate all the help i can get. thanks guys
Old Jun 16, 2005 | 09:55 AM
akula-ssh's Avatar
Default It shouldn't be a huge bad idea if you don't have Quattro...
If you do though, please take those 245's off ASAP: the rolling diameters would be way too different for the Torsen to handle in the long run (and it doesn't help that the smaller tires up front are already half worn, such that the problem is even more exaggerated)
Old Jun 16, 2005 | 10:10 AM
New Member
its cvt fwd....what if i lowered the psi in the back tires more thant he front so it sits lower?
Old Jun 16, 2005 | 10:14 AM
akula-ssh's Avatar
Default Lowering the back tire pressure doesn't make the rear sit lower perceptibly though
What pressure are you currently running on the tires, front and back?
Old Jun 16, 2005 | 10:25 AM
New Member
Default i just put 38 up front and 34 in the back and it's getting better....
i'm going to add 4 psi to each and test it again
Old Jun 16, 2005 | 10:28 AM
Chris not @ Toyo now's Avatar
Default You might check the pressures all around first, chances are the rears are too low....
since the T1S's are worn over 50% and you have new full tread on the back that are a little larger (the 235s are 25.5" dia, 9.5" width and the 245s are 25.8" dia and 9.6" width)you will notice a little difference, but it should not be that noticible. Try getting the car aligned (when was the last time you aligned it) and see if this helps. But it sounds like pressures are not equal...but I would look into 2 new fronts as soon as you can afford it...after all, you want all the benefits of the new T1Rs not just half
Old Jun 16, 2005 | 10:41 AM
New Member
Default i had it aligned 2 months ago..having equal tire pressures made the ride really bad..
the different tire pressures helped alot..but i'm going to order new tires for the front and sell the ones i have right now to a friend. thanks alot i appreciate the help
Old Jun 16, 2005 | 10:48 AM
That is true, CVTs are a little different from the Qs....I forgot that the pressures are different.
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 16, 2005 | 06:11 PM
lawong's Avatar
Default Hey Chris, would he be covered by the 500 mi/45-day Toyo guarantee?
Could he just return the tires and get the correct size tires?<ul><li><a href="http://www.toyo.com/500_mile_offer/">http://www.toyo.com/500_mile_offer/</a</li></ul>
rayjr13
10
Apr 12, 2016 04:43 PM
Captain Rossness
Audi A3 / S3 / RS 3 MKII
26
Sep 24, 2015 05:34 AM
Quetzal
Wheels & Tires Discussion
Sep 23, 2015 07:50 PM
ZPA117
A4 (B8 Platform) Discussion
Sep 8, 2015 11:55 AM
wolfcj
Sep 3, 2015 11:56 AM
