TurboTimer for the 1.8T
Hey people..
where can i get a turbo timer installed in my 2003 audi a4 1.8T here in souther california.
specifically around the la/oc county are.
how much does it cost?, who can do it? or who has doen it?
any info will help
thanks
any info will help
thanks
Just a note on the turbo timer
I don't know if this issue has been resolved but midway through the 02 production there was a change in the alarm system if I am correct. This change means that as the car runs you cannot arm the alarm, so if you have a turbo timer you cannot arm the alarm while the arm is running. I believe there was a fix to this problem, but I am not sure. Search AW and I am sure you will come up with the problem I described above.
Re: Just a note on the turbo timer
its not that you cant run the factory alarm with it, its just you have to manually lock your door; get a greddy one, i installed mine within like 30 mintues
ECS Tuning-Audi
09-25-2015 01:20 PM
