What is this component?
Old Oct 15, 2007 | 09:05 AM
Audi6spd's Avatar
Default What is this component?
<center><img src="http://pictureposter.audiworld.com/79460/a4_engine.jpg"></center><p>I'm looking at purchasing an '03 1.8T (MT) but there is a space in the engine bay that is missing this round shinny component. Can anyone tell me what this component to the left of the yellow arrow is?
Old Oct 15, 2007 | 09:07 AM
x1rider's Avatar
it has to do with the automatic transmission (not present with MT)
Old Oct 15, 2007 | 09:08 AM
skeeball's Avatar
Member
AFAIK, only auto trannys have it.
Old Oct 15, 2007 | 09:09 AM
HeartlessNomad12's Avatar
I was wondering the same thing on my 02 3.0Q MT6
Old Oct 15, 2007 | 09:28 AM
Audi6spd's Avatar
Ya'll are awesome, thanks!
Old Oct 15, 2007 | 09:29 AM
diagnosticator1's Avatar
Default It is a vacuum pump specifically for the brake booster, used with Auto trans only..
The vac pump maintains the vacuum in the brake booster above the minimum required value.
Old Oct 15, 2007 | 09:35 AM
Apparently, all 3.0's have one, but on the 1.8T, only with Auto box.
Old Oct 15, 2007 | 09:59 AM
skeeball's Avatar
Member
I don't have it. But it might have been removed when the blower was put on.
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 15, 2007 | 03:36 PM
Mrkrad's Avatar
Member
Default you could add it to any motor maybe it would help while braking on boost :)
the tiptronic shuts down the DBW at 2500rpm if you are trying to brake stand the car. not sure if the manuals do that too. quite annoying
Old Oct 16, 2007 | 10:30 AM
Default Very true,..
The 1.8T auto box needs it due to the EPC. During certain running modes, the throttle valve is opened a lot and engine rpm is controlled be the VVT and ignition timing. With the TV opened at low rpms, there is not much vacuum in the intake, thus the vac pump runs under ECU control when measured booster vac is to low.
bballfreak
9
Apr 14, 2019 06:59 PM
Kerry G
May 18, 2018 06:12 AM
iaflyer
Mar 3, 2018 12:41 PM
vansoffyomama
Sep 28, 2015 04:38 PM
Cristone
Sep 24, 2015 08:11 AM
