Who knows how to use the A/C
Ok, maybe i am just dumb but I cannot figure how to get the a/c throwing icicles like my Passat used to . Can someone help me out here......
Re: Who knows how to use the A/C
You can lower the temp while on auto and the fan will automatically run at whatever speed it feels it needs to in order to cool the car effectively. If you want the fan to blow stronger increase it manually with the control located in the center between the dual temp controls. Turn on recycled air to get the strongest air flow.
Re: did you set both temps to LO, climate control to AUTO?
if you move it down to low, it will just let in outside air at the temperature it is outside, you want to take it down to the lowest possible temp without hitting low.
J.Russ
10-25-1999 01:08 PM
