Window Switch does not work
Does anyone have the same or similar experience? I appreciate your advice.
Thanks.
Actually the door locks work fine. Only the windows are in the malfunction mode. Did you only replace the master window switch or other switches on each of the door as well?
What confuses me is that how come only the master switch controls the individual window, but not the individual switch on the window itself.
Right now, the driver front switch on the master switch, and all the other three switches on the other three doors show no response. But the three (passenger front, and two rear switches on the master switch) can trigger the windows.
In your case, only replacing the master window switch solved the problem?
Thank you.
The master switch over rides the individual door switches. So it is broken and the individual doors are not able to control the windows. This is a relatively common problem. Here is a link to replacement switches. Like I said, a common fault and an easy fix!
:: www.ECStuning.com :: Now with EXTENDED Customer Service hours!! | FIND US ON FACEBOOK!!
Phone: 1.800.924.5172 - Sales: 8:30am to MIDNIGHT EST | Customer Service 8:30am - 8pm EST
Questions? PM us for a quick response! | Email: Pete@ecstuning.com
FYI, the cause of your problem is a frayed / broken wire in the driver's door jamb. I know since I had *exactly* same issue/symptoms as you and resolved it by fixing the wire.
Simply pull the accordian-like rubber cover to expose the wires leading from the door to the car. You'll see one or more wires that are broken, or about to break.
Since the wires are pretty short (not much give) I found that it is easier to splice an extra piece to re-attach two ends together.
This 'brittle'/crappy wire problem also causes (depending on the wire):
1) Door speakers cutting in/out.
2) Power lock on the door not working.
etc.
Happy New Year!
Thanks.
