Audi a4 2007 2.0 turbo code error
I need help to diagnose Vagcom error :
Sunday,21,June,2015,19:14:21:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WAUAF78E77A132427 License Plate: BOBI
Mileage: 161840km-100562mi Repair Order: bobi 21 6 2015 code error
Chassis Type: 8E (8E - Audi A4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUAF78E77A132427 Mileage: 161840km/100562miles
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 8E0 910 115 P HW: 8E0 907 115 D
Component: 2.0l R4/4V TFSI 0020
Revision: 5EH14--- Serial number: XXXXXXXXXXXXXX
Coding: 0104010A02070120
Shop #: WSC 22705 444 70077
VCID: 2E53E833B9E29E6E36F-807B
3 Faults Found:
000564 - Boost Pressure Regulation
P0234 - 001 - Limit Exceeded (Overboost Condition) - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 161598 km
Time Indication: 0
Freeze Frame:
RPM: 2498 /min
Load: 88.2 %
Speed: 84.0 km/h
Temperature: 81.0°C
Temperature: 21.0°C
Absolute Pres.: 880.0 mbar
Voltage: 13.716 V
008583 - Bank 1; System too Lean at Idle
P2187 - 004 - - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 161597 km
Time Indication: 0
Freeze Frame:
RPM: 777 /min
Load: 16.5 %
Speed: 0.0 km/h
Temperature: 90.0°C
Temperature: 60.0°C
Voltage: 13.208 V
005668 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 161617 km
Time Indication: 0
Freeze Frame:
RPM: 1054 /min
Load: 43.9 %
Speed: 2.0 km/h
Temperature: 94.0°C
Temperature: 36.0°C
Voltage: 13.589 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No SW: 8E3 910 155 M HW: 01J 927 156 HT
Component: V30 01J 2.0TFSI USA 0020
Revision: 00000009 Serial number: 00000001040330
Coding: 0000001
Shop #: WSC 06325 000 00000
VCID: 326BFC43ADDABA8E527-8067
1 Fault Found:
001798 - Transmission Range Sensor (F125)
P0706 - 000 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 82
Reset counter: 255
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
RPM: 864 /min
RPM: 0 /min
(no units): 13.0
Torque: 14.0 Nm
Temperature: 45.0°C
T.B. Angle: 0.0°
Bin. Bits: 0001 0 1
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 H HW: 8E0 614 517 BF
Component: ESP8 FRONT H06 0140
Revision: 00000000 Serial number: 00000000000000
Coding: 0004525
VCID: 2C57E23B8FFEEC7E18B-8079
1 Fault Found:
01119 - Gear Recognition Signal
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 21
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4006
Hex Value: 0x0031
Hex Value: 0x01AC
Hex Value: 0x0000
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BL
Component: A4 Klimaautomat 2833
Coding: 00000
Shop #: WSC 00000
VCID: 6CD7223B1C7E2C7E58B-5000
No fault code found.
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul KAN 0907
Coding: 00014
Shop #: WSC 91588
VCID: 3D71DF7F378475F6BF5-4A3A
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 H HW: 8E0 959 655 H
Component: Airbag 9.41 H12 3840
Revision: 91H12384 Serial number: 0036N0G0K4E0
Coding: 0032607
VCID: 3C77D27B7F9E7CFE88B-8069
Subsystem 1 - Part No: 8E0 910 339 B
Component: BF-Gewichtsens. 002 0070
Subsystem 2 - Serial number: 3HKHW
Subsystem 3 - Serial number: 0001.01.000000200000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332DRB404264C32Gÿ†63
Subsystem 5 - Serial number: 64C32Gÿ†6342DRB404250993Gÿ†63
Subsystem 6 - Serial number: 50993Gÿ†6352ARB401BB7F1F0ÿ†63
Subsystem 7 - Serial number: B7F1F0ÿ†6362ARB401CC9AF32ÿ†63
Subsystem 8 - Serial number: C9AF32ÿ†63729RB401CD4135Mÿ†63
Subsystem 9 - Serial number: D4135Mÿ†63829RB401CD40AC-ÿ
Subsystem 10 - Serial number: D40AC-ÿ
7 Faults Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 107
Reset counter: 39
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 39
Reset counter: 39
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
00003 - Control Module
014 - Defective - MIL ON
Freeze Frame:
Fault Status: 11101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
001 - Upper Limit Exceeded - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 15
Reset counter: 255
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
01213 - Belt Tensioner Igniter; Rear Middle (N198)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 39
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0701
Coding: 02021
Shop #: WSC 06325
VCID: 4189A38F4B7C1116DBD-4A9C
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 951 N HW: 8E0 920 951 N
Component: KOMBI+WFS 4 H14 0200
Revision: 0200 Serial number: 00000000000000
Coding: 0020364
Shop #: WSC 91588 999 96595
VCID: 3561C75F5FB4ADB6775-5072
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0020364
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CG
Component: Komfortgerát T7B 4135
Coding: 11880
Shop #: WSC 06325
VCID: 78FF0E6B582690DEAC3-4A3A
Subsystem 1 - Part No: 8E1959801G
Component: Tõrsteuer.FS BRM 0706
Subsystem 2 - Part No: 8E1959802G
Component: Tõrsteuer.BF BRM 0706
Subsystem 3 - Part No: 8E0959801E
Component: Tõrsteuer.HL BRM 0606
Subsystem 4 - Part No: 8E0959802E
Component: Tõrsteuer.HR BRM 0606
End ---------------------------------------------------------------------
67 69 75 76 77
3 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 161598 km
Time Indication: 0
Freeze Frame:
RPM: 2498 /min
Load: 88.2 %
Speed: 84.0 km/h
Temperature: 81.0°C
Temperature: 21.0°C
Voltage: 13.716 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 161597 km
Time Indication: 0
Freeze Frame:
RPM: 777 /min
Load: 16.5 %
Speed: 0.0 km/h
Temperature: 90.0°C
Temperature: 60.0°C
Voltage: 13.208 V
P1624 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 161617 km
Time Indication: 0
Freeze Frame:
RPM: 1054 /min
Load: 43.9 %
Speed: 2.0 km/h
Temperature: 94.0°C
Temperature: 36.0°C
Voltage: 13.589 V
Coding: 0000001
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 82
Reset counter: 255
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
RPM: 864 /min
RPM: 0 /min
(no units): 13.0
Torque: 14.0 Nm
Temperature: 45.0°C
T.B. Angle: 0.0°
Bin. Bits: 0001 0 1
Coding: 0004525
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 21
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4006
Hex Value: 0x0031
Hex Value: 0x01AC
Hex Value: 0x0000
Coding: 00000
Shop #: WSC 00000
Coding: 00014
Shop #: WSC 91588
Coding: 0032607
7 Faults Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 39
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 39
Reset counter: 39
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 15
Reset counter: 255
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 39
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Coding: 02021
Shop #: WSC 06325
Coding: 0020364
Coding: 0020364
Coding: 11880
Shop #: WSC 06325
Wow! - OK start with the Po234.
This is normally related to the N75 valve. Check the vacuum lines in and out of the N75 for cracks. You can actually put 12v on the terminals and hear the valve click as a check. Replacement valves are about $60. That should also fix your lean error.
The transmission error and the ABS error are usually related. Start with the F125 sensor and check the selector is actually lining up with the transmission to engage the gear correctly.
What happened with the air bags, was this car in an accident recently? Did you reset all the codes and test again or was this just a one off test? If so, do a general reset of all fault codes, if the mil goes out, drive around a few days then test again, if the mil comes on straight away, test again and see what you get.
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-25-2015 11:27 AM
ECS Tuning-Audi
09-25-2015 09:07 AM
ECS Tuning-Audi
A4 (B8 Platform) Discussion
09-25-2015 09:02 AM
ECS Tuning-Audi
S4 (B8 Platform) Discussion
09-25-2015 08:57 AM
