A/C Musty Smell
A/C Musty Smell
I have that typical musty smell coming from A/C upon startup. After the A/C runs a minute or two, the smell subsides. I have seen several posts on here about cleaning out the drain lines for the evaporator and someone posted pictures and a step by step process which seemed like a lot of work as well as time consuming.
Does anyone have any simple fixes to unclog these lines?? I was wondering if its possible to put the car on a lift and from the bottom, use a metal fish or wire and push through from the end of the line clearing any blockage, working your way toward the beginning of the line.
Any comments?
Any comments?
replaced dust and pollun filter,also i use a condition aire in the sys,
take dust filter out and run ac on then spray conition in fan,then turn on heat all the way up and then spray more in fan,it will kill and remove bacteriacide and odors in sys,i will use the whole can,after that if u have more lft over spray filter also,pep boys,any parts houses should have it,hope this helps!
Phil from Detailers Domain uses this product in a lot of his jobs. If you go to the detailing forum you can get more info.
http://www.detailersdomain.com/index...PROD&ProdID=41
Sad thing is is that I only have one dealership near me and they are trash. Long story short, they worked on my car for warranty which they "forgot" to put all of my panels in my trunk together after they finished replacing parts. I got rust out of it, missing clips, and lost time because of them. Never heard an apology once. I'll stick with working on my own cars. Sorry for the rant. I really really hate this dealership's techs/service.
silverTTQC
07-07-2006 02:29 AM
ehsix-4point2
05-11-2005 06:34 PM
X-Tonic Tiptronic
04-29-2004 12:41 PM
