Code 17536
I'm having a turbo problem with my B7 007' with code 17536 Bank1, mixture adaption (mult), system too lean upper limit exceeded, I took it to the dealer and the service advisor told me that the Valves Casket should be replaced as he found oil on the plugs, I replaced it and the problem wasn't solved. I took it to another service center, we checked all vacuum hoses and replaced Bank1 and Bank2 MAF sensors, but unfortunately the problem is still exists.
what happens with me is that the turbo air vacuuming sound get lower slightly until it dies completely.and by the way when I disconnect the Battery for a few minutes the car gets back to normal but it shakes for a around 20 seconds after starting the engine and I lose throttle and after a few seconds the car gets 100% normal, and after driving it for a few miles the turbo dies again slightly.
I don't know if this is relevant but could a jammed intake system be the reason?
Last edited by Ahmad Marei; Dec 16, 2018 at 01:20 AM. Reason: adding an information
