A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
Fogging of the windows
Old Nov 14, 2005 | 01:07 PM
DukeLeto's Avatar
Default Fogging of the windows
Hey,
I haven't been able to keep up with the forum for the past 3 weeks so I'm sorry if someone adressed this subject in the mean time.
Have any of you noticed constant fogging of the windows when the air conditioning is turned on heating in the car? Even if I leave it in auto mode or set the air direction manually every 10-15 minutes the windows will start getting foggy. On the A3 I never had this problem.
Thank you,
T.
Old Nov 14, 2005 | 01:10 PM
bhvrdr's Avatar
I keep mine set on vents and floor only and now mine doesnt fog.
Old Nov 14, 2005 | 02:08 PM
FCastigl's Avatar
Junior Member
i get fogging quite a bit with Econ turned on
Old Nov 14, 2005 | 02:16 PM
a4fever's Avatar
New Member
My dealer told me not to use the ECON mode. Don't recall why.
Old Nov 14, 2005 | 02:26 PM
DukeLeto's Avatar
Default Re: Fogging of the windows
It doesn't matter if it's Auto or Econ. I don't use the Econ mode too much either.
I just remembered the second issue. At the same temperature, the Econ mode blows hotter air, has anyone else noticed that? If I set it for 24°C, for example, it will blow a much cooler air in normal mode than in Econ. I usually use Econ mode just to heat up the car quickly then leave it on Auto, still, I get the fogging. I would ask at the dealer but they had no clue what was wrong when I was missing 16 semerings on the A3, doubt they'll have a clue now.
T.
Old Nov 14, 2005 | 03:32 PM
pyewacket's Avatar
New Member
Default Econ just shuts off the A/C compressor
even when it's cold out, the system still uses the AC to take moisture out of the air. That's why you you're not supposed to use econ and recirculate together in cold weather. It's in the manual.
Old Nov 14, 2005 | 03:42 PM
Tomasz@Startup's Avatar
You either sweat A LOT, or the AC is not working.
bballfreak
9
Apr 14, 2019 06:59 PM
Turguin
Audi A3 / S3 / RS 3 MKII
11
Apr 14, 2017 07:39 AM
iamdrewseph
Oct 1, 2015 11:33 AM
Jiggie
Sep 30, 2015 07:14 PM
NYCtt123
Sep 27, 2015 05:04 AM
