A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
How many miles does a full-tank go on your cars ? mine used to go 300 for a full-tank and now
Old Jun 1, 2006 | 10:26 AM
  #21
GodBlessQuattro's Avatar
New Member
Old Jun 1, 2006 | 10:59 AM
  #22
lowdef's Avatar
Senior Member
Default When I fill up it takes about 16-16.25 gallons...
so for a 16.6 gallon tank, I let it get really low.
I usually drive 10 to 20 miles after the estimated fuel remaining reads 0 miles.
*to give you an idea of the amount of fuel we are using to compare distance per tank*
Old Jun 1, 2006 | 11:53 AM
  #23
kvanwagoner's Avatar
Junior Member
Default Same here 300-320 is my average
I cant see how these guys get so much more...they must have the A/C off and drive slow or something
Old Jun 1, 2006 | 12:04 PM
  #24
mksap11's Avatar
Default do they change formulations where you are? (e.g. winter/summer)
They do up in the Northeast. Even with the change over to E10, I've been averaging the same, if not slightly better, than the winter formulations. Still not as good as it once was, though...
Old Jun 1, 2006 | 12:06 PM
  #25
lowdef's Avatar
Senior Member
Default I definitely don't drive slow...
I use the extra hp from the APR flash! I don't use the A/C too much either...I usually have my windows down and sunroof back which is more inefficient than using A/C anyway.
*before my ecu got flashed I was getting between 350 and 400 miles per tank*
Old Jun 1, 2006 | 12:16 PM
  #26
New Member
doesnt that cause all the gunk at the bottom of the tank to get into the engine?
Old Jun 1, 2006 | 12:36 PM
  #27
lowdef's Avatar
Senior Member
Default If there is 'gunk' in the tank...
it's going to get into your fuel lines regardless of how much fuel is in the tank. If it's bad enough the fuel filter would clog (doing its job) protecting the engine.
Old Jun 1, 2006 | 01:40 PM
  #28
FCastigl's Avatar
Junior Member
350 is about average for me...my best is around 410, but the tank must have been almost empty
Old Jun 1, 2006 | 03:25 PM
  #29
Junior Member
Default I have APR as well and run the 93 octane program but I am only getting 21 mpg
with a 60/40 highwya to city
Old Jun 1, 2006 | 03:52 PM
  #30
lowdef's Avatar
Senior Member
Default My highway/city split is about the same...
averaging ~27mpg.
Could the two different high pressure fuel pumps in use on the B7 (06F127025B vs. 06F127025F) have something to do with it? <small><b>I doubt it...</b></small>
What tire pressure do you run?
