If I purchase 2005.5 without bluetooth, can it be installed as a plug and play?
Also wonder if I wanted navigation, could it be added? Thanks guys.
You can retrofit a RNS-E (nav) into the B7. Choices are either sellers from Navplus.us, where
packages are about $1400-$1500. There are some reputable sellers on eBay that sell units as well (flashed with US software, same as sellers from Navplus). Those are a little less pricey, about $1000-$1200 which include the DVD, antenna, adapters, etc.
<a href="http://stores.vagnav.com/Detail.bok?no=16">Bluetooth</a> package is $850 for just parts alone. You could probably install it yourself but if not, expect to pay a little for labor.
Definitely with RNS-E if you have a double-DIN radio slot. Otherwise, not so sure.
<a href="www.navplus.us">NavPlus.us</a> explains the complete conversion. It really helps if you have the red and white MFD/DIS.
Neither the nav nor the Bluetooth is as good as what you'd get from, say, a Garmin c550. But it is nice to have everything integrate between the radio, the wheel and the display.
