iPhone sync w 2007 A4 bluetooth prep with DIS. No NAV.
been searching the net and the forums for several
days now. It seems that if you have the NAV installed that the iPhone can pair w the A4.
Has anyone had success pairing the iphone to
a NON NAV a4?
a NON NAV a4?
Re: iPhone sync w 2007 A4 bluetooth prep with DIS. No NAV.
mine paired up just fine, it does everything the bluetooth should do i can answer calls and place calls and my phone book come up on the little red screen. I do not have nav nor do i have the audio package. hope that helps
hmmm. OK well. did you have to go through any steps? My Samsung d807 pairs right up. The iphone
just sits there dumbly searching. I've tried
w the bluetooth on and off.
Mine is an early 2007 w the symphony radio.
I wonder if it is a model year thing, maybe
only works w the BOSE radio. grasping at straws:
Does you phone see the message
"connect with audi UHV" ?
that's what I would get on my Samsung.
What steps did you have to go through to pair it?
thanks everyone
thanks everyone
it does say paired with audi uhv. The first time i paired it i turned the bluetooth on the i phone then it said searching, then i turned on the ignition and then it found the car i put in the pin i think it was 1234 the manual said. It all worked just fine good luck with it
thanks. I'll give it another try.
Your 2.0T sounds looks pretty rad from the
specs. Mine is just a 2.0T Q Auto, w convenience
and sport, and the leveling lights. I'm on a
2 year lease so no real plans to chip her.
Only mods were to debadge the rear.
The 2.0T is great even with the auto. As long
as you are not waiting for the torque converter
to catch. The 2.0T and 6AT are much quicker than
the 1.8t and auto.
FWIW. I do have 2 ALFAs both w manual trannies.
As a comfortable daily driver I love my auto.
the 1.8t and auto.
Success : iPhone sync w 2007 A4 bluetooth prep with DIS. No NAV.
Thanks pekb7.
I guess I gave up too soon.
I turned the BT off on the iphone.
turned the BT back on. Iphone >> searching for devices.
Unlock my car. turn key to power on but
do not start the motor. It sees the Audi UHV.
fails to sync the 1st time. Asks me to enter the
pin. I do 1234.
start the car. press the mode button. Wait 3 minutes for my contacts to load.
Now I can dial out via my BT. Shweet !!!
pin. I do 1234.
josemiguelvasc
01-13-2018 05:32 AM
Richard Solomon
9
01-10-2003 02:05 AM
Delaware_Tom
02-07-2002 01:49 AM
