A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
P016 code
Old Apr 22, 2022 | 12:06 PM
Ranham's Avatar
Default P016 code
I’m new here, working on my daughter’s 2007 A4- have changed the timing belt and chain plus the cam adjuster, the cam position sensor the crank position sensor and I’m still getting a P 016 code. Any thoughts where to look next?
Old Apr 22, 2022 | 12:23 PM
Hayabusafalcon's Avatar
Ran:
Engine is mis-timed. That would be my guess.
It is very-very easy to install the timing belt off by one tooth. Did I say very?
I doubt it is mis-timed via the timing chain.
Good luck to you. Let us know what the fault turns out to be. Haya....
Old Apr 22, 2022 | 01:48 PM
Ranham's Avatar
I have checked the timing belt twice just to make sure, it seems to run ok except it shows some negative timing on the live scanner, is that normal? The belt looks to be lined up exact.
Old Apr 23, 2022 | 02:38 AM
Ran:
As I recall from doing the timing belt on mine a few years ago, when the lower cover is removed the timing mark goes with it so I needed to make my own mark on the main crank pulley and engine block. When fitting the belt to the lower pulley it seems like you need to go one tooth negative, then when the tensioner is enabled the lower crank moves back to make it perfect. That's what I recall.
You know you could easily check by taking out the number 1. spark plug and rolling the engine over to find actual top dead center. (Use a dowel or something to put down the plug hole to visually confirm TDC.) Then check the cam pulley marks. Do they line up? If yes the engine is timed okay. If not.....
I've done four timing belts on my various cars over the years. (Lots of motorcycles but those are easy.) I've had to go back and redo the job on one of them 'cause I got the belt set one tooth off. That's only 75% correct. C- grade. Yikes.
Devinv
Sep 15, 2015 11:47 AM
vponomar
Audi allroad
Jan 6, 2010 10:18 AM
BLK01S4
Jul 30, 2004 07:03 AM
cpayne
Audi Original "S" Cars
17
Feb 23, 2004 11:17 AM
