Need help with DTC
Old Jul 29, 2004 | 07:35 PM
BLK01S4's Avatar
Default Need help with DTC
I am getting those code after shop did a timing belt job for me.
1 Faults Found:
16730 - Camshaft Position Sensor (G163): Implausible Signal
P0346 - 35-10 - - - Intermittent
Is this the sensor under the accordion passenger side? and yes its plugged in =]
Old Jul 30, 2004 | 07:03 AM
Ochlockonee's Avatar
Member
Default The CAMP sensors are located on the rear of the head on driver's side, front of the head passenger's
side. Incorrect camshaft timing can set a cam sensor code. If your engine runs just like it did before the timing belt change, I think you can rule out cam timing. Find out which bank the code is for and check that sensor. FYI bank 1=passenger side.
Monkeyboy
VAG-COM Discussion
Sep 26, 2008 12:26 AM
AudiTTboi
Mar 18, 2008 04:50 PM
KingTT
Aug 10, 2006 05:44 AM
urluzn2
Apr 17, 2005 01:27 AM
