quick questions about your mods....
have any of you been able to get your car upto about 350 HP with about 420ft-lb of torque? I have a very specific use for a base 2.0 A4 and just wondering if those numbers are possible at the crank. Also at what RPM are you getting your peaks? Thanks in advance.
it is possible if you do the following....
K04 turbo which adds 98 hp which puts you at 298 hp and adds about 120 lb/ft of torque to give you 321 lb/ft
APR flash which adds 40 hp and puts you at 340 at least. It also adds about 100 lb/ft which would put you at 440 lb/ft
Full exhaust including test pipe or high flow cat which would give you another 30 hp at least, so that means you'd be at 370 hp at least with close to 440 lb/ft
I dont know how much torque is added with an exhaust so im not sure how much more torque you could get but im sure you'd be fine.
I hope i added all that correctly. lol
Good luck!
Good luck!
Couple of revisions...
The K04 turbo making 298hp and 321lb/ft already implies that the ecu is flashed with the appropriate K04 software.
The ecu flash that adds 40hp and 92lb/ft is on the stock K03 turbo. It is NOT added to the 298hp that the K04 makes.
stanlee13
03-11-2003 06:16 AM
cdagza
06-07-2001 11:48 AM
