those who VAGed the b7.....
I used a HEX-USB+CAN interface (USB equivalent to HEX-COM+CAN)
<ul><li><a href="http://www.ross-tech.com/vag-com/hex-usb+can.html">http://www.ross-tech.com/vag-com/hex-usb+can.html</a</li></ul>
Check out vag-com.com website...
there is a manual that explains how to use the cable options they offer. So far, i've done the same as JohnStr - additionally, cleared a check engine fault this weekend (see earlier post)
Cable Source: ross-tech.com for one source for a description of the cable types
it is when you can physically monitor things that the car is doing..i.e air/fuel, rpm, speed, etc..
with the USB cable it doesn't allow you to monitor anything really, it just allows you to change the headlights and seatbelt chime. So it is essentially useless with this car and you need the Hex-USB+CAN interface.
so what you are saying is
that I can program things like one touch open...windows rolldown with remote etc..without the hex-com but in order to scan for codes and such I need the hex-com
I don't claim to be an expert but...
You can do some cool stuff with the vag-com. Modifying localized settings is pretty cool. Being able to understand what kind of fault codes your car is throwing is pretty cool also (helps keep the dealer honest???)
There is an article that takes you a bit deeper into the using vag-com. Check out this link, it offers some insite for how to manipulate parameters via the KWP2000 protocol.
https://forums.audiworld.com/a4/msgs/2181084.phtml
There is quite a bit of vag-com related info on this forum. Also, there are some interestsing open-source projects that I've been meaning to follow up on - if only there where 26 hrs in a day
bvass
12-08-2005 03:44 PM
85-4kq-girl
10-08-2004 06:12 AM
spikie1.8T
08-30-2004 05:13 PM
Random CEL, CEL has been on for a couple of days now and I have VAGed the car several times (more)..
mullarks
08-03-2004 02:22 PM
