A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
Weird problem
Old Dec 31, 2025 | 05:30 PM
marius waterson's Avatar
Default Weird problem
Hi to all i have a weird problem on my A4b7 2L tdi 2006 audi so first of all my check engine is on don't really know what it the problem yet but i replaced the 2 xenon globes but i removed the air filter but after a few months the check engine light cane on so here is the actual symptoms if i start my car now it drives fine all power no limping nothing it gets hot(on temperature not above it) runs fine get to my destination and when i came back cruise control on both ways now im driving back and the cruise control goes away i step on th gas revs goes up but speedo does nothing at all revs keeps rising no increase in speed but only for a little while then my cruise control comes back and power is fine step on the gas and it goes like normal it weird so can't be slipping gearbox cause then it will keep slipping and as i said it does come back full power no slipping don't really have a obd2 scanner i bought a konnwei 450 they said is specific for the audi cars so i hope it will help but does any of you have any idea OBD SCANNER SAYS
P2108
Old Jan 1, 2026 | 10:28 AM
rhythmrider's Avatar
Check you TPS (throttle position sensor it could be bad or going bad.
Or you could have carbon buildup
Make sure the throttle body motor is working correctly.
Might be worth taking it off and cleaning it out,
There are lots of youtube videos on how to do this.
Good luck!
Old Jan 1, 2026 | 10:33 AM
What is the main issue normally cause it's start fine drives fine after a wile it will lose power and wile on the road it will come right again and i can drive full power again
Old Jan 2, 2026 | 10:49 AM
Yes, check your TPS. As previously stated.
Also here is a video on cleaning your throttle body and bits that could help .
Old Jan 2, 2026 | 10:52 AM
Where can I get the book to get to it and is it a very big job removing it
Old Jan 4, 2026 | 04:19 AM
B7Enthusiast's Avatar
P2108 is a diagnostic trouble code that indicates a problem with the Throttle Actuator Control Module, which can affect engine performance. Common symptoms include reduced engine power and warning lights on the dashboard.
Old Jan 4, 2026 | 04:23 AM
Is it fixable or does it need replacement
brianbar
Q3 Discussion
Nov 25, 2025 09:14 AM
ivansrb
Audi A3 / S3 / RS 3
Feb 23, 2019 04:07 AM
mythosrs7
New Member Welcome Area
Oct 2, 2017 08:56 AM
Greg @ Stratmosphere
Mar 26, 2006 07:03 PM
Shamcy
Audi 100 / A6 (C4 Platform)
Jul 12, 2004 11:19 AM
