What’s this line connect to?
Howdy, first post here.
I just found myself in an 05 a4 2.0
The previous owner had started removing the from clip to replace a water pump.
I finished that today, timing belt and water pump went on just fine.
she starts and drives but has a few goblins I need to fix.
one of which is this hose. I can’t for the life of me figure out where it connects.
Here’s the forward connection
driver side, hard line that connects to soft rubber
any insight would be greatly appreciated.
Krash: I believe it to be a sensor line that connects to the brake booster circuit. See attached pic. Unfortunately it appears to be broken off the main fitting. That plastic crap! Geez.
Good luck, Haya....
Edit: I found the cheapest available on Parts Geek $53 but a salvaged one could be had for a few dollars I'm sure. Check out your local LKQ pick a part yard.
https://www.partsgeek.com/gbproducts...oaAqr2EALw_wcB
Good luck, Haya....
Krashdog (03-28-2021)
ChronoGN
06-16-2009 11:16 AM
CMS4
08-10-2006 10:59 AM
