Window Regulator
Has anyone done replaced a regulator on a 2006? Bolts or rivets? And how much of a pain is it to tackle this? I'm figuring the worst part will be getting the door panel off.
Thanks
Jim
If you tackle this projbect, make sure to pick up extra door panel clips, I tried to be careful but I still broke the majority of them getting the door panel off.
The window regulator was not riveted in, which was good. However, finding all the bolts that hold the window frame in place was quite challenging without having any pictures to help me. I was able to google "door panel removal audi B7" and find some helpful hints, but none of the pictures matched my car. There were probably 4 "hidden" bolts involved. If I was savvy enough to use photoshop and hightlight the bolts I would post pictures for the next poor soul. One bolt is hidden behind the speaker in the door, another two are under a plastic cover by the rear view mirror, etc.
There is also a foam membrane inside the door which must be peeled away without puncturing (something to do with the side curtain air bag sensor, read that on a post somewhere).
All in it took me about three hours, probably cut that in half if I ever had to do it again. Lots of time spend figuring how to get door panel off and finding hidden bolts for the window frame. I'll see if I can't figure out how to make the pictures I took helpful.
Thanks
Jim
