A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
Xenon Headlight Flicker Ever Solved?
Old Jul 23, 2007 | 07:15 AM
pjoza's Avatar
New Member
Default Xenon Headlight Flicker Ever Solved?
Did anyone ever have their driver's side xenon headlight flicker problem solved?
I remember reading a post where the ignitor or ballast was to blame.
I just had the whole drivers side headlight assembly replaced with no luck. Under breaking, turning, and acceleration I get a bad flicker.
I just can't find the thread now.
Thanks,
-Peter
Old Jul 23, 2007 | 07:47 AM
r1de's Avatar
Are you sure it's flickering, or could it be vibrating?
Old Jul 23, 2007 | 07:50 AM
pjoza's Avatar
New Member
Default Re: Are you sure it's flickering, or could it be vibrating?
It pulsates from on to off.
Some Videos:
http://208.109.11.4/misc/s4_1.avi
http://208.109.11.4/misc/s4_2.avi
http://208.109.11.4/misc/s4_3.avi
http://208.109.11.4/misc/s4_4.avi
Old Jul 23, 2007 | 08:52 AM
Tanner's Avatar
Default Yes, the ballast was replaced
Symptoms - flickrs a bit. Then it might just go off entirely, but turning the lights off and back on will get it running again. I had to drive to the dealership with the one light not working to convince them that something was wrong.
My left started to do the same thing but taking a lot longer to fail vs the right one.
Old Jul 23, 2007 | 10:34 AM
maaliish's Avatar
Default When you turn xenons on, do they perform the aligning procedure?
If not, you need to recode your Cent. Electronics. I had this flicker issue when I was playing around with the coding.
Old Jul 23, 2007 | 10:49 AM
pjoza's Avatar
New Member
Default Re: When you turn xenons on, do they perform the aligning procedure?
They go through the procedure everytime I turn on the car.
Old Jul 23, 2007 | 08:02 PM
RickS's Avatar
Default My passenger side vibrates, bugs the heck out of me...
only does it when the car is cold and in gear, as in when I am backing out of the garage at home or work. If this is a known problem, is there a TSB? My dealer plays dumb when I mention it to them.
Rick
jlbell
10
Feb 6, 2020 04:12 PM
DKONNI
Chicago Discussion
Jan 24, 2012 04:33 PM
Bariukas
Apr 16, 2007 07:06 AM
Chris_R
Apr 16, 2004 11:40 AM
2.7T NC
Jun 15, 2002 05:47 AM
