2013 A4 Hwy Vibration Issue (Tried all usual Fixes)
#11
thanks all. my plan is to escalate this with AofA, and go to an independent tire shop to get the wheels balanced one last time myself. to prove to the dealer that my car indeed has an issue, i recorded the vibrations on the passenger seat-back using my phone accelerometers. then i did an FFT to clearly show vibrations peaks at 5, 10, and 15Hz. i then took the same data on my other car (370Z) on the same roads, same speed (71-74MPH) and same weather conditions. it's clear from the attached plots that the A4 has a vibration issue. i've sent this to the dealer service manager.
#12
Did they balance with a load force balancer....
I have had all mu tires balanced with the LF balancer this way over 10 years and I have forgot what an unbalanced tire feels like at any speed, my tires/wheels ride as smooth as glass.
#13
and if so, do they really know how to use it? I'm talking about where you measure the rim and tire characteristics and unmount the tire and place it in the correct position where the LF balancer want's it?
The operator does the road force balance test, and if matching is needed, marks the tire and wheel as indicated by the machine's computer, lets the air out of the tire, pops the tire bead from the wheel, turns it on the wheel to match the marks, fills it back up and retests. Audi claims a wheel/tire is in spec if the road force is 20 lbs or less. If a tire/wheel combo cannot be force balanced to at least that spec, vibrations are virtually guaranteed. (The tire is usually the culprit if it can't be force balanced under 20 lbs).
Lots of good info and videos here:
http://www.hunter.com
Note that most, if not all, Audi service depts. these days, have a Hunter force balancing machine. Any good dedicated tire shop shop will also have one. Typically, force balancing runs about $25-$35 per wheel, roughly double that of a standard high speed balance.
#14
both dealerships that i went to used the road force balancing machine and found every time one or the other tire to be out of balance and said they "fixed" it. however, the vibration characteristics of the car haven't changed at all even after 5-6 road force balances, so i have no faith in anything they do at this point. very close to filing lemon law.
#15
#16
#17
#18
same problem
I have a 2013 A4 6MT Quattro (8000 miles) with 18" wheels and Michelin A/S tires. Tires were changed by dealer under warranty since the factory Pirellis were vibrating like crazy at highway speeds no matter how many times they were balanced. With the new tires, vibrations are better but still show up from time to time and are very annoying. There is no problem with the steering or brakes or transmission, just seat vibrations in the cabin when driving alone. Adding passengers alters the mass of the system and shifts the natural frequency enough to move out of the resonance zone (at least this is what I think is going on).
Here's a related thread I found on Audizine that talks about this issue. My post is the last one down. I have taken this to 2 dealers and they have checked everything and rebalanced tires a gazillion times, but to no avail. I would appreciate your input if you've had resonance issues like these with the stick suspension and 18" wheels/tires.
http://www.audizine.com/forum/showth...-advice-needed
#19
Well, since the car is brand new, it's probably not a bent wheel. While it could be a defective tire or something else, more than likely a wheel or two need to be balanced. Don't get ahead of it yet. Occam's Razor says the simplest answer is often the correct one.
#20
I get vibrations on newly paved highways. They go away after some time. Not sure if it has to do with the tires or other. I'm putting new tires on next week and there is a fairly new stretch on I95 around Norwood, MA...
