2014 A4 power outlets not working
The outlets in our A4 stopped working. The first thought is a blown fuse. I performed some searches to find out where the fuse for the outlets are and everything led me to the trunk on the right hand side. However, when I looked in there, if did not have near as many fuse harnesses as the videos did. Can anyone verify where the fuses for the three outlets are? The picture is of the harnesses currently in the trunk.
Note that your car is a B8.5, and information about the B8 (2009-2012) might not relate. My 2009 (B8) has separate 15A fuses for each outlet, fuses 1-4 in row D. Your 2014 (B8.5) has a single 20A fuse 2 in row C (that yellow 20 closes to you).
I lot of this is in your owner's manual, which you can find as a PDF online if you don't have yours.
Thanks to both of you for the reply. I did find the full User Manuals online here: Audi Online Owner's Manual. I just needed to enter my VIN and got the answer I was looking for. It was in the brown (C) fuse panel in slot number two. I pulled that 20A fuse and saw that it was blown.
In my 2009 wagon, there's at the front of the center console under the sliding cover, inside the center console under the armrest, the back side of the center console for the rear seat passengers, and then the one in the right rear of the cargo space. So four outlets, four 15A fuses.
thedenz0
08-21-2016 05:44 PM
Roach
05-20-2007 07:22 PM
