ADS - Suspension errors
Anyway, the VCDS readout is:
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 8K0 907 364 HW: 8K0 907 364
Component: DAEMPFUNGS-SG H08 0052
Revision: 00000000 Serial number: 07080809110002
Coding: 050181
Shop #: WSC 08252 444 57356
6 Faults Found:
01769 - Sensor for Vehicle Leveling; Front Right (G289)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 2
Fault Frequency: 151
Reset counter: 99
Mileage: 8647 km
Time Indication: 0
Date: 2010.05.27
Time: 18:39:33
Freeze Frame:
03262 - Comfort Restriction
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 20
Reset counter: 59
Mileage: 8647 km
Time Indication: 0
Date: 2010.05.27
Time: 18:39:33
Freeze Frame:
Error Code: 2
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 2
Fault Frequency: 6
Reset counter: 99
Mileage: 8648 km
Time Indication: 0
Date: 2010.05.27
Time: 18:40:35
Freeze Frame:
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 43
Reset counter: 99
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
00776 - Level Control System Sensor; Left Front (G78)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 59
Mileage: 8780 km
Time Indication: 0
Date: 2010.05.30
Time: 13:34:18
Freeze Frame:
03263 - Functional Restriction
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 13
Reset counter: 99
Mileage: 8792 km
Time Indication: 0
Date: 2010.05.30
Time: 13:52:20
Freeze Frame:
Error Code: 7
And the car appears to be in suspension limp mode - the suspension is *very* firm (almost as if it's stuck in dynamic mode).
It's probably not both the level sensors going out at the same time - I'm suspecting a control module fault (and replacement).
Luckily, the car is also due for the 5,000mi service... so it's probably not an additional shop visit.
John.
Cheers,
John.
