Alternator Fault Battery Not Charging Woes
#11
So when you're in the measuring blocks and have three of the blocks up, you can click Add to Log and you get the log contents as you've posted here. But just posting the log of a series of clicking Add to Log doesn't provide any context. Don't just post the log here, use the contents of the log to post an informative set of information and context. As is, all I really see is "wow, you got problems".
I would have wanted to see blocks 18/19/20 with engine off. That's your starting point, battery state. Alternator blocks are irrelevant with engine off. We have one capture of that. I presume it's engine off since the voltage is low and the current flow is negative. -27.5A, that's a lot. Did you leave the climate control system on, the DRLs one, the door open, and the radio playing? When I do VCDS work, I turn off the DRLs, turn off the climate control system, shut the doors, mute the radio. I show -10.5A or so. The battery is very low, state of charge is 40%. You should put it on a charger. Expecting to drive around enough to get the alternator to bring it back up to 85% is not the best plan. If it's an AGM battery (I presume it is given the low internal resistance), make sure it's an AGM aware charger. Correct charging process is not the same for AGM vs standard.
Once you had engine running, then another log of 18 to see the voltage and current flow. No need to log 15 or 16, just look and see if the values are fine. I would have watched 18, 14, and 26 with the engine running. What does the BDM say is happening at the battery (block 18 voltage and current), what does the J533 say is happening at the voltage regulator (block 14 and 26). Does the information look good. You logged 26 once, and the values are odd. 0A current, but 127.5 Nm torque and almost 13kW output? Likewise, you had one block 14. J533 said it was specifying 15V, but had no values for field signal or field current. So what voltage was 18 showing at the battery when the engine was running? If it wasn't close to 15V, and was the same as with the engine not running, obviously the alternator is doing nothing. Is it because of the alternator or because of the voltage regulator? Or maybe wiring; the alternator housing should show continuity to the battery negative post. And the B+ output post on the back of the alternator should show continuity to the battery positive post.
#12
Sorry for my insufficient information. Learning on many levels all at one.That first log was actually with the engine running. So a little explanation is in order. Car has been charging all week, verified with a multimeter each time we started it. 20 minute drives to work and back and then a trickle charger on it at night. Each morning the charger said it was charged. Charger is good for ACM. Not sure if the alternator is charging like its supposed to, but the alternator is putting out amperage. Saturday morning it was still charging, drove it a total of 3 hours with 5 or 6 stop/start cycles over the course of the day. Never did check it again. hooked the VCDS up to it this morning and it was not charging. It had been on a trickle charger all night again, but charger said it wasnt fully charged.
The first log I sent was with the engine running. Here are some new numbers. First set is with the ignition off and engine off. Second is with it running. Headlights, radio, HVAC, etc are all off with doors closed in both sets.
Sunday,18,July,2021,19:31:05:20230
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4544.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
Address 19: CAN Gateway (8T0 907 468 M)
19:31:02 Group 001: Power Supply
12.10 V Voltage (Terminal 15)
12.00 V Voltage (Terminal 30)
19:31:02 Group 026
0.0 A Current
0.0 A Current
0.0 Nm Torque
0 W Output
19:31:26 Group 014: Power Supply (Generator)
10.60 V Generator Voltage (specified)
Dynamic-Field Signal
Field Current
3.00 s Load Response Time
19:31:26 Group 015: Power Supply (Generator Status)
Electrical Generator Status
Mechanical Generator Status
Thermal Generator Status
19:31:26 Group 016: Power Supply (Generator)
Not OK Generator Type
Generator Vendor
Generator Size
Generator Control
19:31:44 Group 018: Power Supply (Battery)
12.200 V Battery Voltage
-8.4 A Battery Current
28.0°C Battery Temp. (Estimate)
28.0°C Battery Temp. (Ambience)
19:31:44 Group 019: Power Supply (Battery)
54.0 % Battery State of Charge (SOC)
100.0 % Battery State (as shown in MMI)
79.0 % Battery Aging (derived fr. Load)
126.0 % Battery Aging (derived fr. Output)
19:31:44 Group 020: Power Supply (Battery)
3.4 mOhm Internal Battery Resistance (actual)
2.4 mOhm Internal Battery Resistance (stan.)
31 Ah Battery Capacity (actual/available)
12.30 V Quiescent Voltage
19:32:03 Group 021: Power Supply
Inactive Idle Speed Increase
Inactive Fresh Air Blower Reduction
StatCurStg 0 Quiescent Current Stage (actual)
Yes Auxiliary Heating activatable
19:32:03 Group 022: Power Supply (Battery)
0.00 Battery Input
0.00 Quiescent Current Average
9986 Ah Total Energy Balance
312 Ah Total Energy Throughput
19:32:03 Group 023: Quiescent Current Test
Invalid Quiescent Current Test Result
Invalid Quiescent Current Test Status
This is with the engine running. From what I see, the car is calling for output from the alternator, but its not giving it. The measurements from block 001 show the voltage dropping after the engine is started. The information, or lack-there-of in 15 and 16 leads me to believe that the car isnt communicating with the alternator. Going through the rest of the blocks seems to agree with that. Im not sure what to make of blocks 21, 22 and 23. I see that there is a small increase in block 22 input and drop in the QCA, so does that also mean that the alternator isnt really charging and the car is running off of the battery?
Sunday,18,July,2021,19:43:11:20230
www.Ross-Tech.com
19:43:07 Group 026
0.0 A Current
0.0 A Current
127.5 Nm Torque
12750 W Output
19:43:07 Group 001: Power Supply
11.90 V Voltage (Terminal 15)
11.80 V Voltage (Terminal 30)
19:43:54 Group 014: Power Supply (Generator)
15.00 V Generator Voltage (specified)
Field Current
19:43:54 Group 015: Power Supply (Generator Status)
19:43:54 Group 016: Power Supply (Generator)
Generator Vendor
Generator Size
Generator Control
19:44:07 Group 018: Power Supply (Battery)
12.100 V Battery Voltage
-15.7 A Battery Current
19:44:07 Group 019: Power Supply (Battery)
51.0 % Battery State of Charge (SOC)
19:44:07 Group 020: Power Supply (Battery)
27 Ah Battery Capacity (actual/available)
12.20 V Quiescent Voltage
19:44:25 Group 021: Power Supply
Stage 2 Idle Speed Increase
19:44:25 Group 022: Power Supply (Battery)
0.03 Battery Input
-0.55 Quiescent Current Average
9984 Ah Total Energy Balance
314 Ah Total Energy Throughput
19:44:25 Group 023: Quiescent Current Test
www.Ross-Tech.com
19:31:02 Group 026
0.0 A Current
0.0 A Current
0.0 Nm Torque
0 W Output
Field Current
Generator Vendor
Generator Size
Generator Control
0.00 Battery Input
www.Ross-Tech.com
19:43:07 Group 026
0.0 A Current
0.0 A Current
127.5 Nm Torque
12750 W Output
Field Current
Generator Vendor
Generator Size
Generator Control
0.03 Battery Input
#13
No problems. It's a learning curve. To go over the blocks again, 1 is the term 30 and term 15 as seen at the J533 in the dash. This is the unit that the J367 on the battery negative post reports to, as well as the unit that controls the voltage regulator on the alternator. Term 15 differs from term 30 in that it comes from the term 15 relay, vs direct from the battery. If you were to open the door and connect to the car (you have to open the door or unlock the car or so something to wake the J533 or it won't respond) and read block 1 without turning on ignition, you would see term 15 as 0v.
Blocks 14-16 and 26 are pointless unless the engine is running. Blocks 21-23 are about energy management, not particularly useful specifically to your issue of battery not charging. The blocks you care about are 18-20 regarding the battery, and 14 and 26 regarding the alternator (though as pointed out, only if the engine is running). Thus you see the 10.6v commanded output when the engine is not running; the value is pointless as the engine is not running.
So let's look at the first set, ignition on engine off. 12.2v and 54% SoC; so the battery is not at the preferred charge level (85% SoC). Only an 8.4A draw on the battery, that's really low; I suspect my higher draw is due to all the MMI 2G High equipment in my car. But it's not any particularly bad case here. Then you start the car. The voltage is still the same as with the engine off. That's a really bad sign. The current draw is really low I would think for a running engine, only -15.7A, but it's a draw, not a charge. You should be seeing some + value representing current flow into the battery.
Clearly your alternator is not working. When you go to the J533 (CAN Gateway, address 0x19) in VCDS, there's a button for fault codes. There are no fault codes? There should be a lot of fault codes. You have three considerations here. Either the J533 cannot communicate with the VR over the LIN bus as it should. Either the VR is not doing the job it's commanded to do. Or the alternator is just broken. Have you checked the overrun pulley? That's what broke on mine. Take a stick (any NOT METAL) with the engine not running and the serpentine belt removed and put the stick into the windings so the alternator cannot spin. If you spin the pulley, it should free spin in the direction opposite normal rotation (counter clock wise). It should not spin (because you blocked the movement of the rotor with the stick) in the direction of normal rotation (clockwise). If the pulley free spins in the normal direction, then it's not spinning the rotor anymore. You're getting nothing from the alternator because the engine is not spinning the rotor anymore.
If the pulley is fine, all you can do it dismount the alternator and go have it and the VR bench tested. One or the other is not working.
Do look at the back of the alternator; make sure the B+ wire is actually attached.
#14
Did a fault scan yesterday and forgot about it. Did another one now to get fresh data. Knowing my luck, most of this isnt relevant, but I copied it anyway. I am aware of the lean code and I have been having issues with the passenger door locking. The other engine code and the others I dont know about. The CAN bus fault makes me think its not seeing the VR maybe? The fault in the HVAC makes sense. All of the dates shown line up with the last time the car just died on the road.
Ive had the alternator physically tested and Ive checked it out multiple times each. if none of this leads to a clear solution, I will take it back out and test it and make sure it is physically good again. Everything is terminated as it should be.
Thanks for all of the help and dumbed down explanations. Helps a lot. Happy reading....01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
2E-Media Player 3 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (DL0MA-CAEB) Labels:| 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AL HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H14 0001
Revision: E1H14---
Coding: 010C010A190F0160
Shop #: WSC 22145 444 54035
ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
ROD: EV_ECM20TFS0118K2907115AL.rod
VCID: 79AFE43D695DA2A3C8D-802C
2 Faults Found:
7144 - Please Check DTC Memory in CAN Gateway (J533)
U1008 00 [044] - -
[Diagnostic interface for databus -J533-please read DTC]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 24
Mileage: 289295 km
Date: 2021.06.29
Time: 17:59:06
Engine RPM: 924.00 /min
Normed load value: 9.0 %
Vehicle speed: 0 km/h
Coolant temperature: 93 °C
Intake air temperature: 64 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 12.015 V
Unlearning counter according OBD: 40
4106 - Bank 1; System too Rich at Idle
P2188 00 [237] - -
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 290326 km
Date: 2021.07.17
Time: 18:05:46
Engine RPM: 945.00 /min
Normed load value: 8.6 %
Coolant temperature: 97 °C
Intake air temperature: 44 °C
Readiness: 0000 0000
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AC HW: 8T1 820 043 AC
Component: KLIMA 3 ZONEN H06 0150
Revision: C1000000 Serial number: 01270120090205
Coding: 64002000
Shop #: WSC 06335 000 00000
VCID: 72BDD31134ABD1FB897-8026
1 Fault Found:
03270 - Ventilation Reduced due to Engery Management
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 8
Reset counter: 172
Mileage: 289256 km
Time Indication: 0
Date: 2021.06.28
Time: 21:13:19
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8T0 907 468 M HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0095
Revision: GB300043 Serial number: 4300G091210046
Coding: 000303
VCID: 4BC36EF573C1E0332A1-801E
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Serial number: 1905F691080109
1 Fault Found:
02252 - Generator
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 11
Reset counter: 132
Mileage: 289205 km
Time Indication: 0
Date: 2021.06.17
Time: 11:29:57
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Part No SW: 8K0 907 064 AG HW: 8K0 907 064 AG
Component: BCM2 1.1 H80 0145
Revision: 00002001 Serial number: 0116579173
Coding: 0126023A207A441400B002
VCID: 75B7E80D45C5C6C3AC5-8020
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0040
Serial number: 00000000000000113297
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Subsystem 3 - Part No SW: 8K0 959 591 HW: 8K0 959 591
Component: J245 PS130 H06 0037
Subsystem 4 - Part No SW: 8K0 959 591 HW: 8K0 959 591
Component: J394 PS225 H06 0037
3 Faults Found:
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 101
Mileage: 289205 km
Time Indication: 0
Date: 2021.06.17
Time: 11:59:22
02616 - Fuel Tank Cap; Unlock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 101
Mileage: 289205 km
Time Indication: 0
Date: 2021.06.22
Time: 19:28:22
00166 - Access/Start Authorization Switch (E415)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 147
Mileage: 289314 km
Time Indication: 0
Date: 2021.06.30
Time: 07:26:48
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8K0 959 792 D HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000008419711
Coding: 011C03204E00410001
VCID: 40D949D94A87336BCF3-8014
1 Fault Found:
02115 - Locking Unit for Central Locking
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 171
Mileage: 289205 km
Time Indication: 0
Date: 2021.06.17
Time: 11:59:22
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 195 AD HW: 8T1 035 195 AD
Component: Symph3 Sirius H01 0301
Revision: 00000003 Serial number: AUZ5Z4H1070542
Coding: 040200020102850043D9070800
VCID: 79AFE43D69DDA2A3C8D-802C
Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
Component: Display
2 Faults Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 101
Mileage: 289205 km
Time Indication: 0
Date: 2021.06.17
Time: 11:29:33
03157 - Functionality limited due to Communications Disruption
Freeze Frame:
Fault Priority: 6
Fault Frequency: 11
Reset counter: 171
Mileage: 289205 km
Time Indication: 0
Date: 2021.06.17
Time: 11:52:50
Freeze Frame:
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 10000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Revision: E1H14---
2 Faults Found:
U1008 00 [044] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 24
Mileage: 289295 km
Date: 2021.06.29
Time: 17:59:06
P2188 00 [237] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 290326 km
Date: 2021.07.17
Time: 18:05:46
Coding: 64002000
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 8
Reset counter: 172
Mileage: 289256 km
Time Indication: 0
Date: 2021.06.28
Time: 21:13:19
Coding: 000303
1 Fault Found:
02252 - Generator
Freeze Frame:
Fault Priority: 2
Fault Frequency: 11
Reset counter: 132
Mileage: 289205 km
Time Indication: 0
Date: 2021.06.17
Time: 11:29:57
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 101
Mileage: 289205 km
Time Indication: 0
Date: 2021.06.17
Time: 11:59:22
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 101
Mileage: 289205 km
Time Indication: 0
Date: 2021.06.22
Time: 19:28:22
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 147
Mileage: 289314 km
Time Indication: 0
Date: 2021.06.30
Time: 07:26:48
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 171
Mileage: 289205 km
Time Indication: 0
Date: 2021.06.17
Time: 11:59:22
Component: Display
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 101
Mileage: 289205 km
Time Indication: 0
Date: 2021.06.17
Time: 11:29:33
Freeze Frame:
Fault Priority: 6
Fault Frequency: 11
Reset counter: 171
Mileage: 289205 km
Time Indication: 0
Date: 2021.06.17
Time: 11:52:50
Freeze Frame:
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 10000000
Bin. Bits: 00000000
Bin. Bits: 00000000
#15
02252 - Generator
There's your whole problem. So the reason the J533 isn't showing the output statistics from the VR is because it's not getting any communication with the VR. The J533 is wanting to tell it to go 15v output, but it can't.
At this point, you have to look at the plug on the VR on the alternator. There's only one pin, it's the LIN bus line that the J533 and J367 (battery monitor) share with the VR. The J533 is the master, the BDM and VR are slave components. Check voltage between the pin and a good ground point; you should see it moving around as an average value as the LIN bus bounces back and forth between low and high value. Maybe 5v or so? Display blocks 18/19/20 while you do this; that will ensure there's LIN bus communication going on (the J367 has to send the values to the J533 for it to send them to the OBD port). If you're not seeing any voltage, there's likely a wire break between the J533 and the VR. If you are seeing a variable voltage value, the wiring is probably fine and the issue is likely the VR.
The wonder is when the LIN bus is not connected, the VR should default to some kind of output voltage. Yet you still see no voltage output lift (the voltage is the same as the battery voltage, engine on or off). Thus I wonder if the VR is controlling the alternator correctly; are the brushes passing exciter current to the magnets so they actually do their thing, etc. The alternator+VR as a whole in your car is clearly not working correctly, assuming the wiring is good.
#16
I will run that test tonight and get back to you. That battery still wasnt fully charged (per the battery charger) this morning, but I hope to be able to actually get a log of everything when it is charging today or tomorrow.
Thanks for the help!
#17
Ok, battery is charged per the trickle charger. I have included a log with all of the points for 3 scenarios. Key in/ignition off, ignition on and finally engine running. All of these are with headlights off, radio off, HVAC off, drivers door open and dome lights on. I also did the test with the LAN wire on the back of the alternator. With the car at idle, I was getting 11 volts consistenly, so no idea what that means. I will try to include a graph from that process. everything from 18, 19 and 20 appeared to stay the same while i was testing the LAN with a meter.
Monday,19,July,2021,20:38:03:20230
www.Ross-Tech.com
20:37:25 Group 001: Power Supply
0.00 V Voltage (Terminal 15)
12.30 V Voltage (Terminal 30)
20:37:25 Group 026
0.0 A Current
0.0 A Current
0.0 Nm Torque
0 W Output
20:38:24 Group 014: Power Supply (Generator)
Field Current
20:38:24 Group 015: Power Supply (Generator Status)
20:38:24 Group 016: Power Supply (Generator)
Generator Vendor
Generator Size
Generator Control
20:38:44 Group 018: Power Supply (Battery)
Battery Voltage
Battery Current
20:38:44 Group 019: Power Supply (Battery)
20:38:44 Group 020: Power Supply (Battery)
Quiescent Voltage
20:38:59 Group 021: Power Supply
20:38:59 Group 022: Power Supply (Battery)
0.00 Battery Input
10009 Ah Total Energy Balance
316 Ah Total Energy Throughput
20:38:59 Group 023: Quiescent Current Test
20:39:39 Group 001: Power Supply
12.20 V Voltage (Terminal 15)
12.10 V Voltage (Terminal 30)
20:39:39 Group 026
0.0 A Current
0.0 A Current
0.0 Nm Torque
0 W Output
20:39:50 Group 014: Power Supply (Generator)
Field Current
20:39:50 Group 015: Power Supply (Generator Status)
20:39:50 Group 016: Power Supply (Generator)
Generator Vendor
Generator Size
Generator Control
20:40:21 Group 018: Power Supply (Battery)
12.400 V Battery Voltage
-12.7 A Battery Current
27.0°C Battery Temp. (Estimate)
27.0°C Battery Temp. (Ambience)
20:40:21 Group 019: Power Supply (Battery)
82.0 % Battery State of Charge (SOC)
20:40:21 Group 020: Power Supply (Battery)
2.6 mOhm Internal Battery Resistance (actual)
52 Ah Battery Capacity (actual/available)
12.60 V Quiescent Voltage
20:40:31 Group 021: Power Supply
20:40:31 Group 022: Power Supply (Battery)
0.00 Battery Input
317 Ah Total Energy Throughput
20:40:31 Group 023: Quiescent Current Test
20:42:20 Group 001: Power Supply
13.70 V Voltage (Terminal 15)
13.60 V Voltage (Terminal 30)
20:42:20 Group 026
0.0 A Current
50.0 A Current
0.5 Nm Torque
0 W Output
20:42:44 Group 014: Power Supply (Generator)
14.50 V Generator Voltage (specified)
48.4 % Dynamic-Field Signal
1.250 A Field Current
20:42:44 Group 015: Power Supply (Generator Status)
OK Electrical Generator Status
OK Mechanical Generator Status
OK Thermal Generator Status
20:42:44 Group 016: Power Supply (Generator)
OK Generator Type
0 Generator Vendor
3 Generator Size
0 Generator Control
20:43:15 Group 018: Power Supply (Battery)
14.100 V Battery Voltage
11.9 A Battery Current
29.0°C Battery Temp. (Ambience)
20:43:15 Group 019: Power Supply (Battery)
111.0 % Battery Aging (derived fr. Output)
20:43:15 Group 020: Power Supply (Battery)
3.0 mOhm Internal Battery Resistance (stan.)
50 Ah Battery Capacity (actual/available)
20:43:47 Group 021: Power Supply
20:43:47 Group 022: Power Supply (Battery)
0.03 Battery Input
0.49 Quiescent Current Average
20:43:47 Group 023: Quiescent Current Test
www.Ross-Tech.com
20:37:25 Group 026
0.0 A Current
0.0 A Current
0.0 Nm Torque
0 W Output
Field Current
Generator Vendor
Generator Size
Generator Control
Battery Voltage
Battery Current
Quiescent Voltage
0.00 Battery Input
20:39:39 Group 026
0.0 A Current
0.0 A Current
0.0 Nm Torque
0 W Output
Field Current
Generator Vendor
Generator Size
Generator Control
0.00 Battery Input
20:42:20 Group 026
0.0 A Current
50.0 A Current
0.5 Nm Torque
0 W Output
OK Generator Type
0 Generator Vendor
3 Generator Size
0 Generator Control
0.03 Battery Input
#18
I wonder if doing something with the plug addressed anything, because it's working fine now:
The time stamps are too far apart, but the voltage actual and commanded are similar, battery current is a positive charging value, and we have field statistics from the VR.
The two trios to bother adding to log are 18,19,20 for battery and 18,14,26 for alternator (no point unless engine running). If you need to do the others, make it 1,15,16 (no point unless engine running) and 21,22,23. But again, those data are not particularly valuable for this issue.
You see how with term 15 inactive (ignition off), there's no values from anything such as the J367 (no values in 18/19/20). Only block 1, which is values direct from the J533 itself. So it's not operating the LIN bus until term 15 is active.
#19
So I should have been more clear in my post from yesterday. Messing with the plug and putting the meter on it took place after all of these logs. I graphed 18,19 and 20 while I did it and nothing changed, so I didnt log it, but tried to attach the graph, but ran out of time to figure it out.
The first time I had the engine running yesterday it didnt charge. Values reflected that as well. I shut it off and started it up again right away and then it started charging. That's when I took the last set of numbers.
This is typical. Get a full charge on it and it will be fine for 4 or 5 days then it will crap out again. Let it sit on the charger for a couple days and get a full charge, then its fine again.
#20
I'm not sure what to say then. There's a clear working vs not working indication, but as for a trigger condition, I don't know. Is the wiring sketchy, is the VR sketchy, is the alternator sketchy. It could even be flaky wiring at the starter; the large wire from the battery positive goes to the TV22 block (center of plenum chamber, where the positive jump start post is) then to the starter then to the B+ post on the back of the alternator.
I think if you have a situation where your voltage is low again with engine running (11 or 12v, vs 13 or 14v, just measure it across the jump start posts under the hood), you know the alternator is not functioning. First, I'd check voltage between the B+ post on the back of the alternator and the housing of the alternator. Make sure you at least measure the battery voltage drop there. If not, there's a wiring issue. (be care touching that B+ post not to ground that lead against the alternator housing). If that's good, unplug and replug the 2-pin plug to the VR. See if that restores operation. If not, then there must be something unreliable about that VR would be the best guess.
