A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
Battery coding
Old Sep 30, 2022 | 05:29 PM
xandermacha's Avatar
Default Battery coding
I have a 2010 a4 b8 I don’t know if I coded my battery right I got a 95ah 950cca diehard h8 I didn’t really know which Ben code to use because there was none on it so I looked it up for a while and tried one it was accepted. Can anyone let me know if I did it right?
Old Sep 30, 2022 | 06:26 PM
drgertol's Avatar
@xandermacha P/N 000-915-105-DK is a conventional flooded lead-acid H8 starter battery. If youf replacement is the same type/size, just change one of the digits of the serial number to "recode". --g
Old Sep 30, 2022 | 08:16 PM
SMac770's Avatar
Community Builder
Community Influencer
If it's a wet-flood H8, then DK should be correct.
If it's an AGM H8, then it should have been CE.
Appears the only AGM for DieHard are the Platinum AGM.
The battery type and size your car was made with would be confirmed by the battery PR code.
You'd have to find your PR codes sticker and find the Jxx code. H8 wet-flood would be J1U.
Battery size 7 is H8 wet-flood, as expected for rev DK.
But the J533 seems displeased about something, never seen battery type not ok.
Maybe it just needs some time. Everything else looks as expected.
Old Oct 5, 2022 | 08:33 AM
I recoded using CE instead of DK these are the results does it seem ok?
Old Oct 5, 2022 | 09:31 AM
SMac770's Avatar
Community Builder
You're missing the front question. Is the battery an AGM or not an AGM? That's all that matters, along with the battery size. The J533 seems to be happier with it defined as an AGM, but is it actually an AGM?
Old Oct 5, 2022 | 09:33 AM
yes it’s a diehard platinum agm 95ah
I thought I said it at beginning but I guess not that’s my bad it is an agm battery
Old Oct 5, 2022 | 09:45 AM
SMac770's Avatar
Community Builder
Ok, so yeah, then you've corrected the coding to the proper part number revision.
Interesting that the J533 was able to determine that. Never had screencaps documenting the situation. I guess it figured it out because the concluded internal resistance is simply too low for a typical wet flood.
jastreb
VAG-COM Discussion
Mar 31, 2024 06:40 PM
Andreas Frank
Q5/SQ5 MKI (8R) Discussion
Mar 5, 2023 10:21 AM
gstas25
VAG-COM Discussion
Mar 2, 2017 03:09 PM
DesmoTesta
14
Jun 9, 2007 10:27 PM
DM-S4
11
Nov 2, 2005 02:10 PM
