Driving brand new 2012 A4 from NYC to Boise - break in?
I'm on the verge of buying my first Audi, and I'm pretty excited about it. I found a great deal on a brand new 2012 premium plus A4, it has 42 miles on it.
My challenge is that I'm moving cross country to Boise from New York August 3rd, and even if I bought it today I don't have time to put much mileage on it.
Would I need to take backroads to whole way, going from 30-75 miles per hour? Would changing speed from 50-80mph on the interstate be enough variation? It's just over a 2,000 mile trip and I'd like to make the trip as quickly as possible.
I'd appreciate any input.
As much as the back roads might be a nicer drive, the interstate will be ok on your way back.
The key isn't to vary the vehicle speed, but to make sure the engine RPM varies a bit. Not sure if you are getting a 6 spd manual or 8 speed auto. Either way, just keep changing the gear you are in so that you are cranking away a few 100 miles at a time at exactly 1,600 rpm (as an example)
if you can, I'd try to stay off of the cruise control. If you are worried about speed traps, the car has a speed alert you can set up (ie for 65 mph) in case you drift a little higher than you would like to be.
Enjoy the ride!
Enjoy the ride!
Varying RPMs and avoiding full throttle acceleration for 500 miles is Audi's recommendation for break in. (Others may disagree but I'm a believer that Audi ought to know best on how to break in their cars; I've followed the manuals' instructions for break in with 4 Audis since 2001 and none of them have used excessive oil or had engine problems in over a total of 300K miles).
So, I would say to stay off the interstates as much as possible for the first leg then you'll be ok to get on the highways for the balance of the trip. Do NOT use cruise control for the first 500 miles.
Some bonus advice: I'm assuming you will have a full load since you're moving. If so, set your tire pressures to the max load PSIs as noted on the door label. When you get to your destination and unload, reset the PSIs to the manual's recommended normal load PSIs and tweak up from there as desired to find a good compromise between handling and comfort.
You have a dilemma to consider. You need the factory fill oil in the sump during the first 5000 miles. The engineers rely on the particles shaved off during first run to finish machining the engine. The oil has a one year life span once it is exposed to the products of combustion.
I don't know what advice to give, change the oil now and risk having the engine never seal up, or leaving it alone but depletion of the additive package might cause other premature wear problems.
I would call Blackstone Labs and ask their advice. You could pay them for an oil analysis test, and that would tell you how much of the additive package is left. There might be enough to mke it safely to 5000 miles.
This last bit of advice about the oil is not quite clear to me. Do I need to change the oil before the first 5000 miles? And what would I be asking black stone labs about the oil? Thanks
I don't see where the issue is - The factory oil fill is good for 5k Mi. He is planning a 2k MI trip - glowder will still have 3k Mi of oil life.
One thing though is to bring or buy a spare Qt of approved oil for the trip, My 2012 used a Qt total in the first 5k mi or so and then hasn't consumed since.
Just a good idea as it can be tricky to find the right oil at all highway gas stations.
Since the 2012 demo the OP is considering is at least one year old, Moviela is referring to the 12 month expected life of the oil, not the mileage which is very low. It is something to consider.
What if I just have the oil changed now, here in NYC before I drive cross country?
One thing to be aware of though. The 5000 mile service is free but I believe it states 5000 miles or one year, whichever comes first. If they do it now, that might be considered the free service and you would have to pay for the oil change at 5000 miles on your own. (about $100). See what they say - it's not a lot of money. You should be able to get it covered one way or the other through negotiation.
