Five engine error codes at the same time
I cleared the codes, drove the car, rescan few times, nothing reappeared, however I don’t feel confident that this was a glitch, or something bizarre and it is not pointing to a problem.
The engine is 1.8tfsi petrol, turbo, 160 hp, 2009 Audi A4.
Theses are the error codes: P0118 P2016 P2008 P0343 P0190 - All of them are Intermittent, so maybe the ground wire needs checking?!
I’m attaching few screenshots as well.
Hope someone can point me in the right direction.
TIA
As a programmer, I'm well aware of bugs. This might very well be one. Don't magnify this. Keep on driving and if reappears you can investigate further.
None of your DTCs except p0190 show up in the version of the service manual that I have which covers the later engines so I can't comment on the specifics of the other error codes. In the service manual I have P0190 which has the malfunction criteria "High fuel pressure sensor voltage > 4.8 V"; but, that does not necessarily mean it is a voltage problem. It could be high pressure; but, then I might expect a P0910 so it might be a voltage issue causing that error unless your ECU does not support P0910.
Ground connections can always be an issue; but, having multiple ground issues would be unusual unless those sensors have a common ground point. I don't have the service manual for your car so can't tell. The one thing I have come to learn about Audis is that they are notoriously sensitive to the 12 volt system voltage. Aside from the battery getting decrepit, the B8s have a not uncommon issue with deterioration of the 12v primary wiring inter connecting the alternator - starter - front distribution point so it might be worthwhile checking that.
I don't know whether OBD11 supports logging. If you had VCDS you could set up to log the 12 volt system voltage while you took the car for a spin. If the 12 volt system voltage crashes really low during starting or is doing some funny things while driving around. If the voltage is taking some significant excursions that might tell you that you have a voltage control issue on the charging system that needs investigation. Not unusual on a 15 year old car.
Of course, you could clear the faults and they might never return.
If the 12 volt system voltage crashes really low during starting or is doing some funny things while driving around. If the voltage is taking some significant excursions that might tell you that you have a voltage control issue on the charging system that needs investigation….
I will post if any updates.
Cheers guys
With regards to the previous idea related to possible problems with the voltage or the ground wiring - if this was the culprit it would affect multiple devices and I would get much more error codes, but since it affected only these 4-5 devices and they are all connected together with the same connector this definitely tells me the the issue is local, related to wiring or connector. Big thanks to SMac770 who provided the information that all these devices are connected together.
One more thing - while checking today the harness I saw the black wire on the green 3 wire connector lost its entire insulation 😳 attached photo
Any idea what is connected to this connector? This is super weird and very concerning problem. I assume I should expect this thing to continue with other wires over and over again and probably to be going worse.
PS: Found it , it is Connection piece Knock sensor (#29 on the schematics). It is very odd that only the black wire which I’m assuming is the ground one based on its color got peel off, on the other two the insulation looks alright.
As for the codes, they are intermittent, not confirmed. I don't put much effort into intermittents. Clear them and if they don't come back, it's fine. Codes do not self clear rapidly. If you were playing with the 14-pin at some point, then the codes are probably from then. Codes have freeze frame data that says when they occurred. Don't know how you see that data with OBDeleven.
