glove box
glove box
trying to remove a glove box on 2010 a4 to check the modules for mmi but i found 8 bolts screws but watching youtube videos there is 12 at least. i found one on the side 2 at the bottom 3 inside the box 2 above them 1 in back wall inside the glove box but there is something similar to cd changer and i need some kind of removal key where can i get it
If you have a disc unit in the glove box, it's removed using the same keys as the in-dash disc unit. I needed trim pry tools too, so got a kit on amazon that had all of it.
If you look at the five pairs of dash unit removal keys, it's the middle one in the lower row. So you can find them alone on amazon and eBay as well. At least the ones in this key are very sturdy.
Just look for Audi MMI removal keys or such.
Not sure what you are saying. "Check modules for MMI". What are you trying to do? The ECU is in the engine bay, no where near that area. The main brains for the MMI system is behind the climate controls. Did you mean MMI or AMI?
yeah i am talking about mmi modules in mine audi i did not take a pic that pic above is from website that gave me step by step troubleshooting and i removed my glove box and there was ecu module next to radio and when i disconnected all lights on speedometer and all the lights went out i connected it again and lights came on so that was ecu module . i am trying to troubleshoot mmi modules mine is basic 3g mmi no navigation just radio and other vin number oil level tire pressure instruments
That might have been the instrument cluster control module, but it certainly wasn't the ECU. The ECU is in the engine bay. (ECU = engine control unit, though maybe you're using it as a generic term electronic control unit?)
What's the actual problem you're trying to resolve? Did you do a scan and you have some DTC from some module? Or some operational issue?
i am trying to find modules for mmi system i found amplifier in the back and according to one step by step how to fix mmi site it says that there is one behind the glove box and behind the ac and radio
