A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
Old Aug 23, 2016, 10:43 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A4 (B8) Lighting Guides
Print Wikipost
Help with A4 upgrade to S4 LED Taillights !
Old Jun 15, 2009 | 11:36 AM
phelipe's Avatar
Default Help with A4 upgrade to S4 LED Taillights !
Hi guys,
I just made the upgrade from original taillights to LED (S4 OEM). Everything was easy, including the plug. But now the my car think the taillight is broken, so keeps me giver "lights error"
So I need the VAG code to program the car. The exactly section is 46, I need some kind of security access to change the confs.
Has anyone here changed the original taillights to the LED version?
Tks in advance,
Phelipe
Old Jun 15, 2009 | 07:07 PM
awhk's Avatar
Config via vagcom is not possible as it requires access to BCM2 module to be installed to your central electronic system. Even if the BCM2 is installed, ppl say the BCM2 is not accessible via vagcom as well. The solution would be purchase a dongle from kufatec or other source to install the BCM2 module on your car and the tail lights will work properly. The brake light arrangements should be different after the module setup as well.
joseph_c
Q7 MK 1 Discussion
Jun 14, 2019 12:44 PM
tmac2015
Sep 20, 2015 04:29 PM
2Fast_TDCi
VAG-COM Discussion
Jan 26, 2013 06:31 AM
DPT21
Apr 28, 2007 11:23 PM
Mountian_A4
Nov 11, 2001 06:11 AM
