Infineon video
Infineon video
Just got back from Infineon Raceway this evening and thought I'd share this with you guys
http://www.youtube.com/watch?v=cJQ-idzEeyc
Nice vid.
Do you mind sharing what software you are using to edit? I have vids that I'd love to post but they are each 20-30 minutes long so obviously they need to be cut down...
BTW on T1, if you track it out there a little longer, you will have a smoother turn-in to T2. It might feel like you are out too long but the compression from the rise to T2 will give you plenty of traction to get over to the apex. It just allows you to completely avoid the ripple in the pavement between T1 and T2. While not critical at 8/10 driving, it will definitely unsettle the car as you try to set up into T2 for T3. And as I'm sure you know about Sears Point, each turn is linked to the next turn not the usual "turn/straight/turn" track config so smoothly maximizing use of the track equals faster lap times. Oh the joys of a technical track.
Jet Jockey/A4 Pilot
Canadian Discussion
10-20-2006 11:49 AM
escapA8
06-03-2002 08:28 AM
