iPhone4 + iOS 4.2.1 + Audi BT Adapter = still all good
Do you have the AMI too? If so, what happens when you plug into the AMI and try to play music to the BT adapter? Where does the sound come out? Do you have the choice? Is the screen locked? Thanks.
I don't ever plug it in anymore. I do everything via BT. I do have the AMI adapter but you can't use it at the same time since the Audi BT MUsic adapater plugs in to the same spot.
Did you buy the Audi Bluetooth add-on that come with the usb file that updated radio concert III (symphony)??
http://www.iamaudi.com/audi-music-in...tooth-adapter/
only issue is you don't get track info on the MMI. But I don't really mind since I have my iPhone mounted just left of the MMI anyway.
Does this BT adapter allow you to stream music and still dial/receive phone calls via Bluetooth phone interface?
Is there 2 Bluetooth devices that the phone connects to? (separate for phone and media?)
1. Does this BT adapter allow you to stream music and still dial/receive phone calls via Bluetooth phone interface? YES
2. Is there 2 Bluetooth devices that the phone connects to? (separate for phone and media? YES
Can you do Bluetooth for two phones?
I have a 2010 A4 with 3G MMI. Is it possible to pair the Bluetooth system with two different phones so that either one will work, depending which one is in the car, without having to go into the SETUP menu and switch devices?
