A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
new 2012 A4 jukebox question
Old Apr 27, 2012 | 11:15 AM
djjuice's Avatar
Default new 2012 A4 jukebox question
OK i guess i have 2 questions. Just wondering if the jukebox can display album art on the A4, i've seen it on youtube for an A1 and A6 and up. I couldnt make it work if it does (i'll figure it out)
also. Does it support itunes playlist files? i'm hearing conflicting info.
I am using an MMI plus
Thanks
Old Apr 27, 2012 | 11:20 AM
djjuice's Avatar
i'm guessing with the playlist file, its a matter of telling the playlist file to locate the song on the sd card, but itunes uses the E:\name.m4a
format
maybe have to figure out the format the jukebox will recognize
Old Apr 27, 2012 | 11:30 AM
djjuice's Avatar
ok so i figured out the playlist problem, that was easy
so basically I just need to know if it can display album art
thanks again in advance
Old Apr 27, 2012 | 01:22 PM
UmIsThisThingOn's Avatar
Current/3G MMI will not show album art. It has been confirmed that the new MMI for MY13 A4 will, since it's the newer version from A1/A6/A7/A8.
Old Apr 27, 2012 | 02:05 PM
Alphatero's Avatar
How exactly did you figure out the playlist problem?
Old Apr 28, 2012 | 09:24 AM
djjuice's Avatar
I saved all the music to my SD card, exported the play list .m3u file (placed in same directory as music files)
opened the playlist file in notepad and just removed the directory it listed for the files to just the file name of the track.
so basically instead of E:\xxxx\xx.m4a i just had it say xx.m4a
Worked with no problem after that, hopefully that helps
Old Apr 29, 2012 | 05:14 AM
Alphatero's Avatar
And just to be clear here, when you access lists on the jukebox now, in addition to the four supplied "Artists" "Tracks" "Albums" "Genres, it lists your playlists also?
Old Apr 29, 2012 | 06:10 AM
Barrels41's Avatar
I have an old disconnected Iphone 3s hooked into the Ipod cable in the glove compartment. I though the jukebox only copies mp3s. I doesn't rip CDs either? I assume you play music directly from the memory card?
By the way my 2012 A4 B&O does not let me voice tag radio stations like my 2009 A4 did.
Old Apr 30, 2012 | 05:53 AM
djjuice's Avatar
the jukebox imports my aac files just fine, even the protected ones from itunes. I did it to test and had no issue. I deleted them since its easier to just update the sd card
Old Apr 30, 2012 | 05:54 AM
djjuice's Avatar
let me test this
