SD Card...
from what I've read on a couple different forums:
SDHC is supported on 2010 A4's.
In 2009's only SD cards were supported (not SDHC) however;
if a 2009 model, your car may be eligible for a MMI upgrade which would enable SDHC support.
Do you have nav?
Do you have nav?
It's more complicated than that -- it depends on the hardware version and software version from what i know. I know my Feb '09 build date Prem+ w/o Nav -- thus symphony -- with SW 301 will accept SDHC cards.
Search here and/or Audizine and you should be able to find the full story.
Any dealer service techs reading this care to release v 3.01 out into the "wild" along with the original image of v 2.01?
No nav, just a regular Audi stereo. What confused me is the manual, it states that the slot can accept up to 32GB SD card. Correct me if I am wrong but I have never seen a 32GB "SD" card as far as I understand the "HC" stands for "high capacity" and every card which is 16GB and up is considered to be a high capacity.
By the way how do you check for a built date?
The build date is written at the bottom of the B pillar on the drivers side.
You can also check the version of the MMI to see if you have version 3.01. I think the version is written somewhere in the car menu.
I did not have much time this morning to look for a software version but I did look at the b-pillar, my built date is 05/2009, does this mean that I have a 3.01 version?
You would have to check the MMI to be sure, but that's a fairly late '09 build date -- chances are good, IMO. My Early Feb build has 3.01 (the car was at the dealer late Feb and the B-pillar has 2/09 as the build date, so I think it had to be early Feb).
