Significant error codes causing LARGE issues
Those are reading well over 12 volts
If misfire codes re appear, there are a pile of things that can cause misfires. The fact that you appear to be getting misfires on all four cylinders suggest that the problem might be fuel related rather than ignition related. It would be unusual for all four coils / plugs to go bad at the same time. Find and then check both the short term and long term fuel values. The decimal values for the PID identifiers should be 6 (short term) and 7 (long term). If the trim values are high positive numbers that means that the ECU is adding fuel to correct a lean running condition and lean ( high AFR values) can cause engine misfire. Off the top of my head I don't know the PID for the cam chain adaptation value. See if you can find that value. If you are approaching 5 deg you may have a cam chain issue which can cause valve timing issues which can lead to misfires.
An obvious question - is all the engine scheduled maintenance up to date? Is this engine an oil burner?
Faults:
02252 - Generator
You've got a lot of work to go on that vehicle. Errors all over the place; lot of them are known/common.
But the engine stuff, well, P0018 is chains, so looks like you're pulling the engine to validate the timing. It's basically saying the bank 2 (cyl 4/5/6; left side of car) intake cam position sensor is not reporting in time with the engine crank position sensor. You'd need a scope to really challenge that error. Misfires, SAI, lot of work ahead for you.
But that's a S4 3.0T, so not really related to anything here in the A4 forum, which is generally about the 2.0T. The B8 S4 forum is https://www.audiworld.com/forums/s4-...iscussion-134/ You should start a clean thread with your own specifics anyway.
Ok, so there's some issue with the Generator (02252 = generator), but what is the issue with the generator? It leaves out the actual error code, as well as all other information about the DTC.
