UK: Audi A4 Automatic Estate. 2009 lights on front Passenger not working.
I have an Audi Automatic Estate 2009. I have just replaced the Cambelt as it was time to change it. When I started the car the Bulb came up so thought when I get home will check and replace bulb. but just as I was driving home a notice came up saying mainbeam malfunction and then left indicator not working. This is all the bulbs are not working on the passenger front light assembly. Back lights and drivers side working fine. Also when I press open car with fob flashing yellow one side driver side fine no light passenger side not working. Because all lights seem to not be working is it fuse or what I am experience as for all bulbs to go is strange. Can someone please explain what I am experiencing as they were working well before I had my Cambelt replaced. Now have lost all my lights on passenger Front.
So help would greatly appreciated
I assume it's just not plugged back in. There's no fuse per se, but you can check the fuses for the J519 in the driver's end of the dash to see if any blew. "8 and 10" come to mind, in the brown or red columns.
Unplug it, turn on the headlamps, check the voltage from pin 6 (12v to the low beam bulb) to pin 5 (ground for the low beam bulb) [on the harness plug, not the headlamp]. Do you read 12v? If not, what about pin 6 to chassis ground (jump start post on the strut tower)? If still no, there's no 12v coming from the J519, or there's a wiring break along the way.
Am taking it back to the garage as it could be a earth wire may have been de placed they said to bring it back and they will sort the problem. Thanks
Garage have fixed the problem a electrical connection was not seated properly So no lights on the passenger front but now have all lights working.
