VAG 02616, 02615 and 03041
I have recently done technical inspection at Audi service center(Poland) and came to know two fault as mentioned in below screenshots,
#1 Service center informed me that 02616 and 02615 is due to fuel cap lock/unlock issue and it needs to replaced which cost 400 PLN. My question is whether this needs to be addressed immediately? as i do not see this fuel cap lock concerns me! everything works just fine except fuel door locking when i lock my car.
#2 i have no idea about this issue and when i asked to the service guys they said you do not want to worry about this! Can anyone please let me know what this faulty code(03041) is and whether it requires any immediate action from my side ?
Thanks.
Thanks.
I've had the codes for the fuel filler door codes for years. I've not had the physical problem (fuel door not locking/unlocking) in quite a long time, but I used to have the fuel door not unlock the first time when I unlock the doors. Would just relock/unlock and it would normally release after a few tries. Only once did I have to actually fall back to the emergency release in the trunk. You can buy the actuator for $68 on ECS. You're basically doing this (though that's an A7):
If you don't care that the door is not locking, then up to you decide your time vs money vs convenience.
Thanks for your response!
As you said this codes is not concerning me, also it looks like my fuel door does not have any connection with my car lock/unlock! so for now i am going to ignore this and will consider during my next service :-)
A4dre2K
01-13-2003 08:02 AM
allroaddog
Audi allroad
9
09-30-2002 07:52 AM
