A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
What's the coolest coding setting on a B8?
Old 11-08-2014, 04:29 AM
  #31
Former Vendor
Carista's Avatar
Originally Posted by Fox Fader
Can we use this to program a second key?
No, we don't have that feature as of now. We might add it in a future version if it's technically viable.
Old 11-12-2014, 01:26 AM
  #32
dap1974's Avatar
Originally Posted by Carista
As you guys know, many different features/settings can be configured (a.k.a. coded) on an A4 B8. Auto mirror tilt in reverse, hidden MMI menu, DRLs on/off or set to use LEDs, fogs, etc., comfort-close windows & sunroof via remote, disable seat belt ding, needle sweep at startup... and many more.
What's the one you can't live without? What made the most difference to you when you changed it?
Here's the list I've collated over the years for the options I know can be coded via VCDS on the A4 B8, I am currently working on changing the ACC settings.
I think the best feature that's been added, would be enabling the hidden MMI menu as you can make other changes as a result without connecting any leads etc to the car. Another important security feature change is the alarm activation time when the door is opened with the plastic key, as standard its set to sound the alarm after 15 seconds and this has allowed 'certain types' to gain access to the cars and the OBD and make changes that allow them to steal the car.
1) Disable After Wipe Of Windscreen Wipers
2) Disable Amber Corner Lights
3) Disable Key Warning (Keyless Models)
4) Disable LED Wink On Turn Signal
5) Disable Lights On Warning
6) Disable Navigation And Phone Warning Messages While Entering Data At Speed
7) Disable Seatbelt Not Being Worn Chime
8) Enable Adaptive Brake Lights
9) Enable Hidden Menu Via MMI
10) Enable Ambient Interior Lighting Control (Via Hidden Menu)
11) Adjust Bluetooth Microphone Sensitivity (Via Hidden Menu)
12) Adjust MMI 3G Splash Screen (Via Hidden Menu)
14) Enable Import CDs to MMI's Display (Via Hidden Menu)
15) Adjust Radio On Time After Car Is Turned Off (Via Hidden Menu)
16) Enable Battery Meter (Via Hidden Menu)
17) Enable Adjustable Foot Well Lighting (Via Hidden Menu)
18) Enable DIS To Show Efficiency Program (MY2010+)
19) Enable Optical Rear Parking For Cars Without Front Parking Sensors
20) Enable Automatic Gear Selection Shown In DIS
21) Enable Automatic Hill Hold Assist ‘Lite’
22) Enable DRL (Daytime Running Lights) Selectable Via MMI
23) Enable DRL (Daytime Running Lights)
24) Adjust LED DRL Brightness During Indicator Operation (Daytime Running Lights)
25) Enable Rear Tail Lights On With DRL (Daytime Running Lights)
26) Enable Euro Parking Lights That Turn On Via Indicator Stalk
27) Enable Fog Lamp Activation During Turn Signal
28) Enable Front Turn Signals As Parking Lights
29) Enable Headlights On All The Time During Ignition
30) Enable Independent Fogs Control With High Beam Activation
31) Enable Gauge Test And Needle Sweep
32) Enable Lap Timer
33) Enable Remote Operation Windows And Sunroof
34) Enable Release Parking Brake Without Putting Foot On Brake
35) Enable Release Parking Brake Without Putting On Seatbelt
36) Enable Mirror Tilt When Reversing
37) Enable Speed Through MMI
38) Enable TPMS (Tyre Pressure Monitoring System)
39) Enable VIM (Video In Motion) Via MMI
40) Adjust Audi Rear Parking Camera System Switch Off Speed
41) Adjust Audi Drive Select To Specific Preset (Comfort, Auto, Dynamic or Individual)
42) Adjust Headlight Washer Duration
43) Adjust Headlight Washer Cycle Quantity
44) Adjust Fuel Consumption Figure in DIS
45) Enable Adaptive Cruise Distance Via MMI
46) Installation Of Hitch / Trailer Electronics
47) Enable Headlight Converter Under 'Car' (Tourist Mode / Driving Abroad - MMI 2G)
48) Adjust Fuel Tank Characteristics
49) Adjust Steering Angle Sensor Calibration (Must Be Followed by Active Steering Basic Settings)
50) Adjust Active Steering Basic Settings (Must Be Completed Directly After Steering Angle Sensor Calibration)
51) Enable Single Beep On Door Closing (Using Audi Alarm Siren)
52) Enable Double Beep On Door Opening (Using Audi Alarm Siren)
53) Adjust Language In DIS
54) Enable SDS (Speech Dialogue System)
55) Adjust Back-up Camera Picture
56) Electric Memory Seats (With No Memory Seats Installed)
57) Disable Automatic Rear Window Wiper Whilst Reversing
58) Disable Please Release Parking Brake Message Whilst In Gear
59) Disable Window Lock Button On Driver's Door
60) Adjust Drivers Window Up And Down Increment
61) Disable Drivers Window One Touch Down
62) Disable Drivers Window One Touch Up
63) Disable Drivers Window One Touch Down And Up
64) Disable All Windows Up
65) Disable Drivers Side Rear Window Down
Old 11-13-2014, 08:19 AM
  #33
freeBase's Avatar
Default Radio and Media control settings
Is it possible to tweak the steering wheel controls for the radio and media player? In my 2005 A4, the left turn wheel would scroll through radio presets simply by turning it while the radio was on. Now it takes several button presses to get to the presets menu and then every even then you need to press the wheel on each station instead of it selecting it automatically. Same goes for selecting tracks on Media source (i.e. iPhone). On the old Audi, the left scroll wheel would let you skip to next/previous track, now nothing.
I just got my 2015 A4 and find the MMI to require A LOT of button presses to do very simply tasks. Am I missing something? Is it possibly to reprogram the button/****/scroll wheel behavior?
PS: if anyone knows of a good tutorial (besides the one Audi released), please let me know. I've read the manual twice, but still find the system to by clunky.
Old 11-13-2014, 07:20 PM
  #34
Fox Fader's Avatar
Nice. Now if I can get an elm327 that will work I'm all in. Mine will pair, but that's about all it'll do, even with another app.
Old 11-19-2014, 07:39 AM
  #35
Fox Fader's Avatar
My car doesn't have the smart key.
Which button on the remote do we press to get the windows to come down?
i have a manual transmission, when i go to reverse my passenger mirror does not tilt down. Is it because of the manual?
Thanks.
Old 11-20-2014, 04:18 AM
  #36
Fox Fader's Avatar
Forget it, I think I figured it out. Lol
Old 11-24-2014, 10:26 AM
  #37
Fox Fader's Avatar
When you enable the windows up or down settings in Carista, A4 and Q5 models add a new menu to your MMI (under the CAR menu). That was it.
Old 11-24-2014, 11:05 AM
  #38
Former Vendor
Carista's Avatar
Fox Fader, I'm glad it's working for you
About the mirror dipping in reverse: it's not about the manual - it should work with manual cars too. But it may depend on whether you have power seats and the right type of passenger-door ECU (module). Have you tried that setting in Carista? Also, it only works if you leave the car's mirror switch set to the passenger side (I think... or was it the other side? or middle? I don't remember, but try it in all positions).
Old 11-24-2014, 07:42 PM
  #39
Fox Fader's Avatar
Thanks, I'll give that a shot.
Old 11-26-2014, 07:01 PM
  #40
Fox Fader's Avatar
That was it , needed to be in the passenger position. Thanks
Quick Reply: What's the coolest coding setting on a B8?
