19" Tire Replacement
Just wondering if anyone has gone through purchasing a new set of tires for the 19" sport rims (summer performance tires, I believe they are Hankook). I noticed yesterday there was a bubble in the sidewall of one of mine, which I'm not sure if that should be a major concern or not. The dealership recently told me when I came in for an early 20k service that I should be watching the tread on my right front tire but the others are fine.
I think I'd prefer something with a slightly thicker sidewall if that's even possible. These things are brutal.
I was just talking with a buddy about tires this week. I'm at 28k, and something to the replace my Hankooks is not far off. He replaced his with Michelin Pilot Sport 4S, and says "they handle just as well and they have a smoother ride." I know I'm looking for something a little less jittery. Having had good luck with Michelins in the past, I'm going to give these a shot. They're a Tire Rack best seller with a bit higher treadwear (300) than my OE Hankooks.
I run 36F/33R. The car rides and handles great at those pressure. I tried running a couple psi higher and the ride becomes noticeably harsher and turn in becomes noticeably slower due to a smaller contact patch with the road.
Another thing worth mentioning to people viewing this post is that if your replacing your 19"s (summer tires) and are really concerned about ride comfort Conti's are probably a better choice. I find the 4s ride fine but they are performance tires, not marshmallows. Best way to describe this is that they communicate the type of road your on, not mask it., If you drive on a road with a rough texture vs a smooth freshly paved road you'll notice the difference.
Thanks for the advice guys!
Yeah honestly, after reading through a bunch of the reviews on tires I was sort of leaning towards the P-Zero Nero set for price/performance. But I found a decent deal on Costco for the 4S, and they have the best ratings by a long shot over the other tires, especially in dry performance vs treadwear.
I'm also seriously considering doing a 255/35 setup instead of the 245/35. I'm assuming that this wont void any warranties I have on the vehicle since it's a lease, but I might want to double check with Audi to make sure. I went over the idea in detail with one of the Tire Rack CS associates and they have the size listed as a recommended size, with no noted concerns for rubbing.
Hopefully the added width and more importantly sidewall height will yield slightly better ride quality on the 19's. It still falls under the general 3% rule.
https://www.tacomaworld.com/tirecalc?tires=235-35r19-255-35r19
https://www.tirerack.com/tires/surve...earDiameter=17
https://tires.costco.com/Product?ItemNo=1248703&SearchID=255%7C%7C%7C35%7C% 7C%7C19%7C%7C%7C3%7C%7C%7Cen-us
https://www.tacomaworld.com/tirecalc...5r19-255-35r19
https://www.tirerack.com/tires/surveyresults/surveydisplay.jsp?type=MP&width=255/&ratio=35&diameter=19&rearWidth=255/&rearRatio=40&rearDiameter=17
Load rating of 255/35 is 96. 245/35 is 93. This difference will most likely negate any ride comfort difference you'd gain in side wall height. Basically a sideways move. Plus optimal wheel width for 255's is 9". Audi won't accept 255/35 at lease end as load rating and size is not what came on the car originally.
The larger tire 255/35, interestingly enough weighs slightly less than the 245/35
https://www.michelinman.com/upload/m...t-sport-4s.pdf
Why would that negate the ride quality difference form the tire wall height?
