2017 A4 coding tweaks
#1251
Did you install console buttons with parking button?
I wasn't be able to make this working for years after I installed kit
I don't remember how exactly I coded but I played with my ODBEleven and finally made it work
I think they updated their software somehow
It was pretty well noted to follow coding
I mounted the button for auto-hold.
does anyone know coding / activation?
I mounted the parking sensors in front and side (the car have the rear sensors).
does anyone know coding / activation the visual representation on MMI and park assist?
My friend have a same car with this option. can I see or copy the coding?
#1252
Hello, I don't know if it is a right place but according to this thread – after some coding with my A4 b9 late 2016 (with almost all features available in stock) I have lost the heated seats in front .
When I press the heat button, 3 led are ON and after 1sek goes OFF. Same for both seats (L/R). Ventilation works fine. Back seats heat works fine as well.
I don't know when and what (coding) was the cause of that.
Do anyone have any idea where to look?
What could goes wrong?
OBDeleven does not have Gataway for 06 controller that have Seat parameters to do a full scan as I was told by other users form Facebook VCDS group.
What I have done with OBDeleven:
– Enable ACC default distance in MMI
– DRL (Daytime Running Lights) On/Off Option in MMI
– Google Earth without Audi Connect subscription
– Enable ability to Rip CD's to MMI "Jukebox"
– Enable Laptimer shown in VC
– Enable Needle Sweep (not so impressive with VC)
– Parking Assist Camera - Turn Off Speed 20km/h
– De-Activation of Start-Stop via A/C
– Combine the park assist 360 camera view with the OPS In the display
things that was already in stock:
– Gear selection (D1,2,3.. or S1,2... shown in VC)
– Automatic PDC Front
– Enable & Pair a Second Phone via Bluetooth simultaneously
– Turn off range limiter for Comfort Window System
– Right mirror drop on reverse
#1253
Hello, I don't know if it is a right place but according to this thread – after some coding with my A4 b9 late 2016 (with almost all features available in stock) I have lost the heated seats in front ��.
OBDeleven does not have Gataway for 06 controller that have Seat parameters to do a full scan �� as I was told by other users form Facebook VCDS group.
Code 47 value back and everything is working now.
Cheers!
#1254
– Google Earth without Audi Connect subscription - how did you do it?
#1255
#1256
My car has working Audi Connect menu with all options but the license for each function is expired. As Google Earth is working that Google Search is not. Traffic information is ON but there is no information on the map.
#1258
scutustudios.com
Speaking of the coding tweaks...
Can we code swap the Engine Auto-Stop/Start state to be OFF when the car starts and become ON when pressing the button?
It's so annoying that the engine shuts off for everything, including at a STOP sign! Just too much wear and waste of gas for a functionality that is supposed to help us instead of killing that starter too early and burning so much extra gas for no reason!
#1259
For now it's only available for A6 C7, for A4 B9 only thing I found that really works is to shut down START/STOP function regarding A/C panel is working or seats are heated or ventilated.
#1260
scutustudios.com
The only one I found is to turn off the system completely with the below option:
