2018 A4 18 inch wheel spec for better look
Hi, My tire is 245/40/18 but it looks small to me. I want to have wheels to be more outward by upgrading wheels but keeping the current tires.
Current one is 18x8 wheel. Is buying 18x9 ET35 good choice? Does it fit well?
Any suggestions are appreciated and pics are much more appreciated if you have something I want already.
Please check the pics of mine.
What do you mean by "looks small"? Are you just trying the push the wheels outward ("to be more outward")?
A wider wheel doesn't actually move the position of the tread/sidewall very much. The industry rule of thumb is that for every 1/2" change in rim width, the tire's section width will correspondingly change by approximately 0.2". So going up an inch in wheel width will cause the overall tire width to increase by 0.4". Half of that will be visible outboard, so your sidewalls will appear to be 0.2" further out, relative to the wheel well.
The extra 5mm of offset of a 35 will make a difference, but only another 5mm (0.2") if the 40mm I see as stock is correct. So a new set of wheels would get you about 0.4" or 10mm.
Wheel Spacers may be a cheaper solution. Car-specific, 15mm spacers for about $65/corner. I'd stay away from the "universal fit" $25 ones.
Well said. Spacers will give the car a more aggressive stance. And it’s a much cheaper alternative than buying new wheels if you plan to keep 18”.
Adding spacers will probably be the easiest way to get the look you want but it will also change the suspension geometry so the car will feel different. The suspension designers locate the contact patch in a very specific location relative to the center of rotation of the steering for the front wheels. Moving the wheel and therefore the contact patch outward will make steering wheel jump in the direction of a pothole when you hit one and it may also result in some tramlining when driving on roads with grooves from heavy truck tires. You may not even notice the effect but just be aware there could be an unwanted change in the feel of the car with the spacers.
Will they put the contact patch in the same position, yes. Could you potentially experience the effects mentioned in the other post, yes. However, 10mm is not a ton to really notice too much of a difference and youll get used to the change really quick. Doing 20mm is a different story and it could definitely slow down the turn in when handling.
Ive done both in the past. My personal opinion is against using spacers if possible. Obviously, its a much less expensive option, especially if you like the OEM wheels you already have. However, you are putting extra areas of contact between the wheel and the hub. This can introduce extra vibration at higher revolutions as well as areas of minute movement. Having a wheel with the specific offset you are looking for is going to put the wheel directly against the hub for a 1:1 fit.
So again, based on https://www.audiworld.com/forums/tir...calculator.php, I got following result when I upgrade 18x9 et35.
- Outer Position: extend by 17.7mm
Thanks, very good to know 20mm makes that difference. Pushing wheels outward by increasing rim width rather than lower offset will have less impact when cornering, I believe.
