2019 a4 back passenger seat rattle chatter sound
Audi a4 black optics sport edition. After delivery 1-31-19 noticed rear bump stops fell down or weren’t put in right. had that corrected but annoying to go through.
Now for the last last few months i have have been trouble shooting this chattering noise coming from rear passenger seat. had audi replace the rear seat latch and that did not correct the chatter. after folding the seat down and tapping on the back of the seat when down, sound is apparent below headrest.. I have multiple videos recreating the sound. audi dealer scratching their heads which i know is probably tough to deal with as a service tech.
will be taking it back a third time soon. anyone experience the same chatter noise coming from top rear passenger seat?
I do very much love my new A4. It is best looking car in and out that i’ve ever owned and quattro is the better in the snow than my friends in their trucks.
Yes, you are most likely having the exact same problem as I did. It took Audi 5-6 weeks to red order the seat frame. I had the issue happen since delivery of the vehicle with 6 miles, and it was in the dealer for at least 2 weeks.
Here’s what was on my service report:
8W5-885-502-A-CA9
THE RIGHT REAR SEAT BACK FRAME ASSEMBLY HAS A RATTLE WHEN DRIVING ON ROUGH ROADS. ROAD TESTED VEHICLE
AND FOUND THERE IS A RATTLE COMING FROM INSIDE THE RIGHT REAR SEAT BACK FRAME. FOUND THE FRAME ASSEMBLY MAKES
A RATTLE NOISE DUE TO INTERNAL FRICTION FROM THE WELDED COMPONENTS. REMOVED THE RIGHT REAR SEAT BACK
ASSEMBLY, REMOVED THE SEAT COVER AND PADDING AND INSTALLED THE COVER AND PADDING ONTO A NEW SEAT BACK FRAME.
INSTALLED THE SEAT BACK FRAME AND ROAD TESTED TO VERIFY THE NOISE IS GONE.
Thanks for the help. I will pass this along to my dealership!
Sorry to revive the thread.. but have you solved the issue?
It's the back frame seat assembly (8W5-885-502-A-CA9)?
The dealership said it's normal and no tehnical issue!
Thanks!
Thanks!
There was a piece of metal in the frame that came loose and was hitting against the piece it broke away from is what the guy said after I showed him the report from another guy with a similar audi and what that dealer did… Only then was my dealer able to find it and fix it..
The first couple times I took it in for the noise they said they fixed it and they don’t hear it anymore.. But I took the tech out on the road too and he was just baffled, again until I showed that report from the other post above.
I will have to find my own paperwork for what the part was.
Void20 (06-09-2021)
boston_A4_avant
01-27-2004 06:10 PM
jrg
09-02-2001 02:00 PM
PSS // Raj
08-15-2000 03:22 PM
