360 Camera module keeps dropping coding
using OBDeleven, I can see the adaptions / coding in module 5F and gateway are there for the system. In Module 6C it says the control unit isn’t coded.
i have coded this “successfully” for the vehicle several times, which just leaves the no calibration fault on the module. OK.
after a few power cycles, the module keeps dropping the coding with a zeroed long code.
anyone have any ideas or seen this before? Wondering if it’s a bad EEPROM or is a problem with OBDeleven….
thanks you.
