Automatic start stop function malfunction
Old Nov 30, 2016 | 09:57 AM
  #41
steelersmb's Avatar
Originally Posted by munsabin
EXACTLY what I was thinking.
I agree, I just don't want to cause any damage to the car.
Old Nov 30, 2016 | 01:11 PM
  #42
srolle's Avatar
Originally Posted by corradoMR2
A lot of people seem to dislike this feature but coming from a few Lexus hybrids where the start/stop feature is far more seamless than on the A4, I still like the feature as it saves some gas, no issues so far, and most importantly, the shudder is not that bad.
the lexus hybrid actually switches to battery so you can still move the car on electricity in lieu of the combustion engine. so, it's not really stop/start from the vehicle perspective. my es300h does this without me really noticing anything going on behind the scenes.
that's the real annoying part with gas-only systems - there's rarely a good time for the parameters to all be met AND for you to be able to stop the engine for any meaningful period of time from an eco standpoint. it just ends up being awkward and distracting, and even possibly detrimental to the system.
Old Nov 30, 2016 | 01:13 PM
  #43
steelersmb's Avatar
I agree, if I wanted a hybrid, I would have bought a hybrid. It can't be good when you stop and the engine turns off but then the light turns green again or traffic starts moving within a second of the engine turning off. This is the worst feature of any car I have ever owned. I understand you can turn it off but it should default to off and not reset.
Old Jan 19, 2018 | 10:41 AM
  #44
Mbongeni Ndiweni's Avatar
Default Auto Start Stop Function Not Working Drive System Fault
Any feedback on the above issue as yet. I have had the same issue as well. It has come to a point where by my car has to start the engine at the 4th attempt.
if your car has an auto start stop function error I urge you to FORCE the dealership to fix it. This is a cumulative issue don't buy the fact that it seems to be a common issue, it will bite you when the car is out of motor plan.
Old Nov 20, 2019 | 11:15 AM
  #45
Carmenzo Del Aguila's Avatar
I have the same msg, my Audi es A4 2017 with less than 5,000 miles, I will take my car to the Audi shop to check what is the problem I hope should be cover by the warranty.....did you find out what was the problem?
Old Oct 26, 2020 | 08:34 AM
  #46
Kei New's Avatar
Originally Posted by marklar182
Anyone else have this error pop up?
‼️‼️‼️‼️‼️‼️‼️‼️‼️‼️‼️‼️‼️‼️ Long shot but this might help other people it’s an easy fix I have a Audi A4 BlackEdition 2015 Avant... my issue was the same but a few more problems linked to the stop start fault... hazard lights wouldn’t work, rear fog light Blinker sound was twice as fast in both directions but normal on the outside I suspected it could be a bulb, wiring problem or even the ECU playing up I disconnected my battery for 15 minutes and started up the car and now I don’t get any stop start malfunction messages and everything’s working as it should hope this helps!!!! It’s supposed to be a common problem with Audis between 2012 and 2017 don’t go to the dealership before you try this method I had a friend scan my car with a professional device and no fault codes came up Audi wanted to charge me £65 just to do a diagnostics check and then you might as well bend over for the rest
Bpriest1215
A4 (B7 Platform) Discussion
Aug 1, 2018 04:56 PM
HiTEC
17
Feb 25, 2004 11:56 AM
docjan_uk
13
Feb 1, 2004 01:03 PM
Mr. White
Nov 27, 2002 08:40 AM
RobinG
Sep 27, 2002 12:41 PM
