Automatic start stop function malfunction
I don't have a need to turn off auto start/stop. I run in dynamic/S all the time so it is disabled anyhow. (But the error still shows up in that mode with the box as well)
As soon as the start/stop malfunction is shown I can scan with Vcds and the manifold sensor fault will be stored. Reset it and it will come back same time as the start/stop malf. Reset it again in Vcds, remove the box, install jumper, no malf or faults.
I didn't want it to be the box, but it is unfortunately.
If you have Vcds you should check the ecu faults, you probably have the manifold sender fault stored as well.
