A/C Cleaner and A/C drain
I have a B9 A4 and noticed a slight musty smell when I turn the A/C off after it has been running for a while. Does anyone have picture or a detailed description of where the A/C drain is located? I want to go under the car and spray A/C foam cleaner into the evaporator. Or does anyone have a better method? I am also going to replace the cabin filter.
chemengin (09-22-2021)
Turn the A/C off for the last 2-3 minutes of your drive home; it helps to reduce the amount moisture left sitting in the HVAC piping after you've stopped - the musty smell is caused by mould that can grow in the pipes.
Aviator6 (10-02-2021)
svenson69
10
05-05-2005 03:12 PM
JustJeff
14
05-18-2004 03:46 PM
