Coding for turning on Audi Active Lane Assist (all cars with pre sense)
#621
Well that was frustrating, I just hit a wall at a certain point with OBDeleven giving me errors. I have OBD11 software version 0.9.3.0 the information didn't really match the first post information.
The first couple are now "Not Coded" and "Coded". Just assumed I should change them to Coded?
A5 - Frt Sens.
HC>Coded
EFP>Coded
17 - Dashboard
Lane Assistant>Yes
Lane Change Asisstant>Yes (already Yes)
09 - Central Electronics
Heading Control Config>heading_control
44 - Steering Assistance
Heading Control Assistant>Active
I hit the error wall here at the adaptations. The first one would not take and just gave me an error. Also thought maybe it was the security code, but it didn't like the security code either.
5F - Information Control Unit
I tried restarting the application and reconnecting. Nothing changed. I just gave up.
If anyone has any ideas, I'd be grateful. Thank you!
On a separate note, I got these to work:
1. Auto High Beam Assist (I don't think very useful for busy urban areas, it would turn on for split second occasionally and turn off due to other lights)
2. Comfort turn signals to 4 blinks
3. Turned off seatbelt reminder, I always wear mine and make people wear theirs
4. Gauge needle sweep
5. Transmission gear in the gauge cluster
6. Turned on all the reading/map lights when entering the car
7. Turned up seat heaters be 3 on all settings
8. Turned up seat ventilation on highest setting
9. Changed virtual cockpit screen to say A5 instead of A5 quattro
10. Low beams stay on when flash for brighter ouput
11. Active Lane Assist
A5 - Frt Sens.
HC>Coded
EFP>Coded
17 - Dashboard
Lane Assistant>Yes
#623
I had to do a search for what you meant by parameters. So I think I should answer I went by they words. I did not know there was a way to do by bytes on the OBDeleven. I also read that OBDeleven can be a bit finicky as well so maybe I'll try from scratch again today. Thanks for any help!
#625
All reading lights activate when the door is opened
In VCP:
Control unit 09 (electronic central electrical system)
In Long Coding
Set "light_scenario" to "not_active"
In VCDS:
Byte 10 bit 0 enable
#626
Did you end up getting this to work for yours? If so, what model do you have? I have a prestige with presence basic but do have the camera behind the rear view mirror with auto high beams that was enabled from the factory. Would be very interested if I can get this enabled on my model.
#627
Sorry to have completely misread your question...so to change the interior lighting when entering. It wasn't a gain, so going to update my description - wast just turning all the map/reading lights on, I found it here on this German Wiki list (I had Chrome translate German to English): https://audiwiki.bitt-c.at/index.php..._B9_ab_Bj_2015
In VCP:
in "Coding TXT":
59 - Set "light_scenario" to "not_active"
In VCDS:
In VCP:
in "Coding TXT":
In VCDS:
#628
Anyone try to implement the "Auto Entry" feature where the seat moves back to allow easy entry in and out of the car? I enabled it in my car when playing around with the above interior lighting and it's not doing what it said it would. Looking for input. Thanks
#629
In Long Coding
